SolaraGuy.com • View topic - Help on T/B spacer install **Installed**
Postby SleeperSolara » Mon Sep 18, 2006 7:29 am
Well I bought "StockSolara" T/B spacer, that Greg posted for us.
I've talked to "Midias" and "StockSolara" and "DatsRboi" and some local friends.
I've tried what they've said, but wit no luck. :(
I'm doin' it myself.
I've vice grips and had them on there really tight too, they just slip.
I tried the 2 nut method, and all you can get is 1 nut, and the second one will slip right off, cause there isn't enough room for it to hold on.
Tried 1 nut, and then vice grip right behind it, and still slips....
Don't want to mess up anythin', cause i have to drive my car everyday.
It the 2 bolt studs on the bottom of the t/b.
Sorry for the bad picture.....
But when you look at it, all you see is threads.
If you still don't know what i'm talkin' about, they look like head studs.
This waht they look like.
Any help asap would be helpful.
Thanks.
Postby Midias » Mon Sep 18, 2006 10:37 am
Are you turning the right way :o
Mine came out easy with channel locks
Try some penetrating lube, or heat then back out with vice grips. Consider welding a nut to the end and using a socket wrench.
If it helps the studs go all the way through so if you need to drill and tap just go all the way. SO... Now if you super desperate you can cut them off drill a hole insert a stud extractor and turn. Or grind them flat and use a crescent wrench.
Postby SleeperSolara » Mon Sep 18, 2006 11:42 am
Midias wrote:Are you turning the right way :o
Yeah man, i'm turnin' them the right way.
Which way do i turn them?? To the right or left??
I'm turnin' them to the left when facin' the openin' to the intake manifold.
A channel lock????
http://www.channellock.com/
This site says they sell diff types.
I think my dad has some, but would have to find them, they look familiar if those are the right ones.
Can you post a picture man....
Will try to penetratin' lube on Friday.
Wher am i suppose to clamp the vice grips down??
On the smooth part of the double threaded stud??
Postby Midias » Mon Sep 18, 2006 6:25 pm
without a fuss. Spray lube behind them as well to help work it in then tap them a but to break up any corrosion and help the lube penetrate. heat will help to just not a map torch that will probably be too hot.
My channel locks looked like these. Regular craftsman brand.
Postby SleeperSolara » Tue Sep 19, 2006 7:24 am
Midias wrote:without a fuss. Spray lube behind them as well to help work it in then tap them a but to break up any corrosion and help the lube penetrate. heat will help to just not a map torch that will probably be too hot.
Oh, thanks.
Will try it on Friday after work.
Hope that works.
Postby solaraN8 » Tue Sep 19, 2006 5:33 pm
off topic, where can you get the spacers and for how much ?
New Car, 2003 IS300 5mt
solaraN8
Postby SleeperSolara » Tue Sep 19, 2006 5:40 pm
solaraN8 wrote:off topic, where can you get the spacers and for how much ?
Here i found you the link, but you will have to search through the thread to find the link to the actual site to order them
http://www.solaraguy.org/viewtopic.php?t=25765&highlight=spacer
Postby Midias » Wed Sep 20, 2006 3:32 am
Look through the post for stuff by me I put in a link for the spacer with the best price I could find, a coupon code and the bolt sizes you will need to buy.
Postby TMMK Toy » Fri Sep 22, 2006 8:49 pm
What kinda gains does this net with an NA setup with CAI and exhaust?
TMMK Toy
Postby SleeperSolara » Sat Sep 23, 2006 10:17 am
TMMK Toy wrote:What kinda gains does this net with an NA setup with CAI and exhaust?
Should be more torque in the mid-range of the RPM.
Postby SleeperSolara » Sat Sep 23, 2006 1:17 pm
**UPDATE**
I used some parrot beak pliers as my friend suggested.
And wow, he was right.
Those pliers gripped on to the bolt stud.
And came off real easy.
But there is a bit of a tight pull on the T/B sensor on the bottom.
Will have to figure out how to extend the wires....
Postby Midias » Sun Sep 24, 2006 12:43 pm
glad to her you got it on so how does it feel for you. I am curious how the acis mod will fell with the tb spacer in place.
Postby SleeperSolara » Sun Sep 24, 2006 7:43 pm
Midias wrote:glad to her you got it on so how does it feel for you. I am curious how the acis mod will fell with the tb spacer in place.
When you do the ACIS mod you will feel torque hit about 4000 RPM's.
Which will kind-of feel slow cause.... it hard to explain.
But last night when i was drivin' to diff locations for the street races, the torque would hit about 2000 RPM's. :D
I love when the torque would hit about 2000 RPM's, i kept on hittin' the gas a little to have the torque pull, which was fun. :D
I'm happy for now.
Now movin' on the the rest of the suspension mods. :D
Postby Midias » Sun Sep 24, 2006 8:09 pm
SleeperSolara wrote:When you do the ACIS mod you will feel torque hit about 4000 RPM's.
I'm happy for now.
Glad you felt the difference for such a cheap and effective mod. Do you have the ACIS mod right now because I am curious to know if it would be any different with or without the tb spacer. I know a lot of people said it felt like it had no tq with the mod.
Postby SleeperSolara » Mon Sep 25, 2006 7:43 am
I'm happy for now.
Yeah i was suprised too.
That what most people said..... wit the ACIS mod.
Here is the ACIS mod from the tutorial section.
http://www.solaraguy.org/viewtopic.php?t=23293
Users browsing this forum: Google [Bot] and 57 guests
