SolaraGuy.com • View topic - Need confirm? Camry/Solara same exhaust sys always?
Postby DatSRBoi » Sat Sep 23, 2006 8:26 am
Past two years I read allot that the whole header/Y pipe/Catback exhaust system for these two cars were 100% the same meaning no difference throughout any of its year span.. When was both car different on it?
I need to make sure because now Im worried that Im making somehting that wont work on the camry but solara only.
I have no car to prove it on.
Thanks, DatSRBoi
Postby Jai_Jai_Binks » Sat Sep 23, 2006 9:50 pm
i4 for i4 compatibiliy, v6 for v6 compatibility. (for gen 4 camry versus gen 1 solaras). As far as after the resonator...the tail section is the same (hence trd exhausts are same for i4's and v6's).
Postby ---CAMRAZY--- » Sat Sep 23, 2006 10:00 pm
Yes they will fit.
Postby DatSRBoi » Sat Sep 23, 2006 10:01 pm
Ok thanks. Then Project DatSRPipe will continue as planned.
Postby ---CAMRAZY--- » Sat Sep 23, 2006 10:03 pm
DatSRBoi wrote:Ok thanks. Then Project DatSRPipe will continue as planned.
Dont forget to add me to your list, I was like number 3....
Postby DatSRBoi » Sat Sep 23, 2006 10:29 pm
Oh I didnt see you on that list. I putted you into 3. I wont be able to see the numbers I put on it since the pipes will come to be all boxed already I think. Ill see to it I can see the numbers.
Postby CASTRO » Sun Sep 24, 2006 2:31 am
just to add to this little thread since I seem to be the only gen 4 camry on the list is that only difference I've found is after the cat. The greddy cat-back for the solara is longer since the solara is longer than the camry. I have personaly experience as my exhaust came off an old member "kondo"'s solara and onto my camry. we both agreed it looked better (longer) than it did on the solara. other than that, everythign should be the same.
CASTRO
exhausts
Postby 1kdude » Wed Sep 27, 2006 6:26 pm
The best thing to do is compare the part #'s through a toyota dealer.
1kdude
Re: exhausts
Postby DatSRBoi » Wed Sep 27, 2006 8:49 pm
1kdude wrote:The best thing to do is compare the part #'s through a toyota dealer.
Nope. Most of the time parts number are different but the parts at the same.
Postby Hsakuragi » Wed Sep 27, 2006 10:23 pm
not the gen 1.5 ..i believe there are some minor changes..espically on the header area..
Hsakuragi
