SolaraGuy.com • View topic - Whiteline front sway bar....
Postby SleeperSolara » Sat Sep 23, 2006 1:49 pm
What should i get??
A 20mm or 24mm front sway bar.
I know and read about anthoer member breakin' his front sway bar bracket.
So i'm kind-of iffy on these.
But i do know the 24mm is better, but i want to know if that's over kill for daily drivin'.
I have the TRD rear sway bar on the track settin'.
What you guys think??
Postby TMMK Toy » Sun Sep 24, 2006 10:38 am
I dont think you'd want to go too big for the front as the car will want to understeer more, thus eliminating the benefits provided by the rear bar you installed. I'd go with a 20 mm. I could see it worthwhile to replace the front if it it lighter than stock, as more unsprung weight you're removing.
TMMK Toy
Postby MentatGom » Sun Sep 24, 2006 8:34 pm
I like my 24mm whiteline front sway bar. I've never run into any understeer issues. It may be a problem if you were running on tires like something S or T rated. Who even makes a 20mm front? I only know of 22.2mm from Addco and Intrax. I'd recommend go with 24mm. Some details: Gen 4 V6 with Whiteline Sways front and rear(20mm), KYB struts, stock springs and 15" alloys with Falken Ziex ze-512 V.
MentatGom
Postby SleeperSolara » Mon Sep 25, 2006 7:44 am
MentatGom wrote:I like my 24mm whiteline front sway bar. I've never run into any understeer issues. It may be a problem if you were running on tires like something S or T rated. Who even makes a 20mm front? I only know of 22.2mm from Addco and Intrax. I'd recommend go with 24mm. Some details: Gen 4 V6 with Whiteline Sways front and rear(20mm), KYB struts, stock springs and 15" alloys with Falken Ziex ze-512 V.
WhiteLine make a 20mm and 24mm front sway bar.
Another member broke is front sway bar mount brackets, so that's why im' iffy on buyin' the front sway bar.
Postby MentatGom » Mon Sep 25, 2006 12:44 pm
What's the part # on that 20mm?
Here is the current whiteline catalogue for Gen 4 Camry / Gen 1 Solara:
As far as breaking the swaybar brackets... that could be attributed to uneven torquing, or over torquing more than the swaybar itself. The bracket itself may have already had a weak point. I've had the 24mm front on 3 cars now for 2 years and never had a problem.
MentatGom
Postby SleeperSolara » Mon Sep 25, 2006 12:48 pm
MentatGom wrote:What's the part # on that 20mm?
1. Whiteline BTF38 24mm Front Sway Bar(non Adjustable)
2. Whiteline BTR39 20mm Rear Sway Bar(non Adjustable)
Postby MentatGom » Mon Sep 25, 2006 12:49 pm
Yeah you got it right now :D
In your previous post, you had said the 20mm was avail for the front... unless I am not getting what you mean. If you already have the TRD rear, it didn't make sense to me that you would mention the 20mm whiteline rear.
MentatGom
Postby SleeperSolara » Mon Sep 25, 2006 12:59 pm
MentatGom wrote:Yeah you got it right now :D
Naw man i think i got you confused.
My bad.
I have a TRD RSB, and debatin' on 20mm or 24mm front sway bar.
Postby sunrise_solara » Mon Sep 25, 2006 8:49 pm
I say, go with the 24mm, it seems to even out the handling and give a balanced feel, especially through the middle of the corner...
sunrise_solara
Postby RichD978 » Mon Sep 25, 2006 8:59 pm
dude there is no 20 mm for the front . Look again the 20mm is for the Rear. Unless I'm seeing it wrong
RichD978
Postby SleeperSolara » Tue Sep 26, 2006 9:01 am
RichD978 wrote:dude there is no 20 mm for the front . Look again the 20mm is for the Rear. Unless I'm seeing it wrong
Not sure will have to check it again.....
Whiteline front bar
Postby 1kdude » Wed Sep 27, 2006 5:49 pm
I have the 24mm Whiteline front bar and the TRD rear, the front was a real improvement, I recommend it. There is some understeer if I really push it, but its not bad at all.
BTW the 20 mm whiteline bar is a rear bar as stated above.
1kdude
Re: Whiteline front bar
Postby SleeperSolara » Wed Sep 27, 2006 8:01 pm
1kdude wrote:I have the 24mm Whiteline front bar and the TRD rear, the front was a real improvement, I recommend it. There is some understeer if I really push it, but its not bad at all.
Oh, really.
Thanks for the input.
Also thanks for clearin' up the 20mm for the RSB from Whiteline.
Users browsing this forum: Google [Bot] and 57 guests
