SolaraGuy.com • View topic - quick question
quick question
quick question
Postby woa_its_j3ff » Tue Oct 10, 2006 9:34 pm
Sorry if this might seem like a waste of time to you guys, but i just bought an Injen CAI for the Lara and im having issues putting it on. anyone have tutorial or steps needed to help me out?
and lastly, im getting a air/fuel ratio gauge installed in a few days, does getting intake installed means to redo all this gauge setup or will it no interfere?
I used search, but no luck.
sorry if this is a noob question, just thought id turn to you guys for some help here.
- Jeff.
Postby funboy102 » Tue Oct 10, 2006 11:46 pm
the install of the intake shouldn't interfere with the reading on the air/fuel ratio gague. That measurement is taken after the fuel is ignited (correct me if i'm wrong) and so installing an intake won't change how it works (you won't have to change the setup) ... but it might change the reading to more lean or so (you're getting more air).
funboy102
Postby ThatVietGuy » Wed Oct 11, 2006 12:36 am
What's your problem with the Injen?
ThatVietGuy
Postby boneezy » Wed Oct 11, 2006 4:53 am
what issues are you having? its pretty simple to do, getting the stock intake out takes the most time, use your haynes manual if yuor not sure how to take it out.. but youll definitely like it once you install it! have fun!
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby s15lara » Wed Oct 11, 2006 5:36 am
jeff...you got pm
almost there...what do you think?
s15lara
Postby woa_its_j3ff » Wed Oct 11, 2006 5:42 am
^ thanks guys for you time and information.
fitment problem isnt really anything, it just dont seem to fit in right...
I'll post more details up once i try this installation again. thanks you guys.
