SolaraGuy.com • View topic - [Help] on front control arm removal....
Postby SleeperSolara » Mon Oct 16, 2006 7:26 am
Well some of you might know, and some don't know.
But i bought SuperPro poly bushin' for the front control arm, the front and rear bushin'.
Front bushin'
Rear bushin'
Well on Saturday, i tried to attempt to take the front control arm.
Well there are 4 bolts and 2 nuts.
I've been able to take out the bolt that holds the rear bushin' in.
The 2 nuts and the short bolt on the control arm that holds it to the wheel.
The problem is the 2 short botls that holds the front control arm front bushin'.
Pictures below.
How the hell do i take off those bolts since there is barely any room.
I've tried the all my extensions i have for the wrench.
And i didn't work at all, cause there is no way too, hold it down and loosen it.
Any help this whole week would be great.
Cause if i can get help this week, than Fall Break i will work on it again to try to get it off.
Thanks.
Postby CASTRO » Mon Oct 16, 2006 10:04 am
even if you could take them off, you still gotta have someone press the old ones out and press the new ones in. I suggest you jsut bring it to a place to have it worked on, unless you have a huge vice or something.
CASTRO
Postby SleeperSolara » Mon Oct 16, 2006 2:53 pm
CASTRO wrote:even if you could take them off, you still gotta have someone press the old ones out and press the new ones in. I suggest you jsut bring it to a place to have it worked on, unless you have a huge vice or something.
Well i used a very big vice thingy to put the dogbone bushin' in.
I just need suggestion to get the 2 bolts that are in the pictures i posted.
Really don't want to pay to get them installed, if i can do it, even if it is hard.
Postby DaTwUnKrAziEpInOy » Mon Oct 16, 2006 3:09 pm
Air Tools ??
DaTwUnKrAziEpInOy
Postby SleeperSolara » Tue Oct 17, 2006 7:20 am
DaTwUnKrAziEpInOy wrote:Air Tools ??
Unforuntely no.... :(
I do have: Image
Similar to teh one in the picture but from GM and it blue.
