SolaraGuy.com • View topic - Any new ideas?
Any new ideas?
Any new ideas?
Postby rossman945 » Tue Oct 17, 2006 5:27 pm
Hey,
Well I have a Injen CAI, TRD Exhaust, Magnecore wires and bosch platnum spark plugs. Whats another mod that I can add to my car that could free up some more horsepower and that is relatively cheap(couple hundred bucks)? I do relized that I can enlarge my exhaust piping, but I don't want to cause I dont want my exahust to be really loud, I like it how it sounds now. Any suggestions would be great. Thanks,
Ross
rossman945
Postby SolaraBlue » Tue Oct 17, 2006 5:34 pm
......type-R stickers? :P
it wouldnt give you more hp but a new set of sticky tires would be nice. maybe some suspension work i.e. rsb, struts springs etc.....
cant think of anything as far as engine....
Postby rossman945 » Tue Oct 17, 2006 5:41 pm
I have 18s with good tires, and im not messing with the suspension, Im just looking for something simple, does anyone make pulleys for our cars?
rossman945
Postby PXLpainter » Tue Oct 17, 2006 5:50 pm
This one's pretty generic... maybe it'll work. :lol:
Postby rossman945 » Tue Oct 17, 2006 5:51 pm
haha, I guess I had that one coming.
rossman945
Postby lightear » Tue Oct 17, 2006 5:55 pm
headers =)
lightear
Re: Any new ideas?
Postby QuickSEV6 » Tue Oct 17, 2006 5:56 pm
rossman945 wrote:Hey,
Ross
Headers
Rear Sway bar (better handling)
Jims fuel upgrade (fuel lines, pump, regulator and fiter and maybe even upgrade injectors)
Superpro Poly bushings
Short shifter (if you have a manual)
LSD (better traction)
The list is endless - Good luck
Postby QuickSEV6 » Tue Oct 17, 2006 5:57 pm
PXLpainter wrote:This one's pretty generic... maybe it'll work. :lol:
Thats the one I have. It took a little modification, but it works great!
Postby rossman945 » Tue Oct 17, 2006 6:06 pm
Whats LSD? and is upgrading your fuel system possible by doing it yourself?For instance, upgrading injectors? Is it worth it?
rossman945
Postby PXLpainter » Tue Oct 17, 2006 6:11 pm
rossman945 wrote:Whats LSD? and is upgrading your fuel system possible by doing it yourself?For instance, upgrading injectors? Is it worth it?
Well - I've heard accounts from those who have tried it... some pretty wild trips I guess!! :D
Seriously though - LSD = Limited Slip Differential... but do they have such a beast for FWD cars? I had one on my Tundra but that was RWD with a solid axle and transfer case. :-?
Postby QuickSEV6 » Tue Oct 17, 2006 6:13 pm
PXLpainter wrote:Seriously though - LSD = Limited Slip Differential... but do they have such a beast for FWD cars?
Yup! I have one from TRD. I think there are at least two other manufacturers that make them. Try the "search" above.
Postby rossman945 » Tue Oct 17, 2006 6:42 pm
Can anyone elaborate on the fuel system upgrade, costs, is it worth it, etc. Just simple stuff, so I can have a quick idea if everything is worth it.
Thanks
rossman945
Postby Midias » Tue Oct 17, 2006 7:10 pm
Ditch Bosch Platnum Bosch and toyota don't mix
then check this post because I asked the same question a bit ago.
http://www.solaraguy.org/viewtopic.php? ... highlight=
bosch
Postby NRDriver » Tue Oct 17, 2006 7:23 pm
yeah, i havent heard anything good bout bosch with yota's. stay with the denso's
NRDriver
Re: Any new ideas?
Postby JavaJoe_2 » Tue Oct 17, 2006 7:28 pm
QuickSEV6 wrote:Rear Sway bar (better handling)....
I think this is the most cost effective mod.
You will not believe the difference it can make.
Have you ever put your car into a corner and your car wanted to just keep going straight.
Well, this will solve that problem.
There are two settings if you feel that the "track" setting is to harsh.....but I think most of us like it that way. :o
JavaJoe_2
