SolaraGuy.com • View topic - If you have Brembo Sport Rotors (drilled or slotted), HELP!!
Postby nkx1 » Wed Oct 25, 2006 2:23 pm
I have a question on Brembo Sport rotors for the Solara:
I installed Brembo Sport cross drilled rotors for my '99 Solara, and the drilling pattern for the front rotors is opposite on each side; the drivers side pattern faces frontward, and the passenger side pattern faces rearward.
Does your front rotor pattern go the opposite direction on the driver side than the passenger side?
I'm kind of curious to see if they actually sent me 2 left rotors. They assured me they didn't, but I really don't think the pattern should be oposite on each side of the car. Both of the rear rotor patterns face forward. :-?
Thanks.
2001 SLE, Diamond White Pearl
nkx1
Postby krook » Wed Oct 25, 2006 4:37 pm
the rotors are directional. my rotors face forward (the direction the wheel spins) on all of my rotors.
krook
Postby Mr_Chunks » Wed Oct 25, 2006 5:03 pm
yea mine too
you might needa contact them :(
Mr_Chunks
Postby nkx1 » Wed Oct 25, 2006 5:12 pm
Do you guys both have Brembo Sport drilled rotors?
nkx1
Postby SleeperSolara » Thu Oct 26, 2006 6:52 am
I have Sport drilled from Brembo.
What are you talkin' about.
The leadin' drilled holes should face forward.
Take some pictures man, can't help unless there are pictures....
Will take some of mine when i get home.
Postby Solarafreek » Thu Oct 26, 2006 7:10 am
I think he is saying "picture these EXACT rotors on both sides"
If you put this rotor on the other side it will be turning/facing the opposite way. Like putting tire on backwards and the tread rolling the opposite way.
Solarafreek
Postby Mr_Chunks » Thu Oct 26, 2006 9:18 am
mine looks like that one ^
on both sides ( they dont "spin" opposite directions )
Mr_Chunks
Postby nkx1 » Thu Oct 26, 2006 10:42 am
Solarafreek, that is exactly what I am talking about, thanks. The driver side front rotor faces forward, and the passenger rotor faces the oposite way.
Sleepersolara: If you could take pics of the rotors on your car, that would be really cool.
That way I can show the pics to Brembo and prove that they actually did send me two left rotors instead of a left and a right. Up until now, they refuse to admit that they sent me two left ones, and insist that the pattern is correct, even though it is facing the wrong way on the passenger side.
nkx1
Postby SleeperSolara » Thu Oct 26, 2006 2:34 pm
nkx1 wrote:Solarafreek, that is exactly what I am talking about, thanks. The driver side front rotor faces forward, and the passenger rotor faces the oposite way.
Take pictures of the rotors and send them to Brembo.
Will take pictures and load them tommorrow.
Postby nkx1 » Thu Oct 26, 2006 2:39 pm
I plan on doing that sleeper. But they insist that I'm wrong.
I just need to prove to them that they sent me two left ones, and that someone else who has the exact same rotors as me received the correct ones.
Thanks again!
nkx1
Postby Jai_Jai_Binks » Thu Oct 26, 2006 3:29 pm
Good you caught it...
Postby SleeperSolara » Mon Oct 30, 2006 8:18 am
Ok finally got the pictures....
Not that great but you will get the jist of it.
Dirver rotor
Passenger rotor
You will notice that it has 3 drilled holes then 2 drilled holes.
They also face forward too.
Postby Solarafreek » Mon Oct 30, 2006 8:26 am
nkx1 says 1 faces forward, 1 doesnt. He MUST have 2 of the same in the front..lol
Solarafreek
Postby Solorange » Mon Oct 30, 2006 3:03 pm
Id take pictures of what you got and send it to them so they can see for themselves that they are wrong.
Postby nkx1 » Wed Nov 01, 2006 3:35 pm
Thanks for the pics sleeper.
Unfortunately, when I first posted this, I already had installed these on my car.
I think I may be forced to leave them as-is, since they are now used. I really don't want to pay more $$ for a new rotor; Brembo will probably just say it's my fault for not noticing it before installation. It sucks though, since it's tough to notice something like that before the rotors are installed.
nkx1
