SolaraGuy.com • View topic - brakes
brakes
brakes
Postby woa_its_j3ff » Fri Oct 27, 2006 5:47 pm
in addition to purchasing spring/struts. Im also looking at brakes.
What is the exact difference between slotted/drilled rotors, etc..?
And drum brakes.. etc?
still learning. :oops:
( considering brembo like Mr_chunks has on his car with Hawk brake pads )
Postby anttarz » Fri Oct 27, 2006 5:53 pm
brembos are def the way to go. They only make blanks, slotted and cross drilled or the combo. Blanks brake better warp less, cross drilled look better and save pads.
anttarz
Postby woa_its_j3ff » Fri Oct 27, 2006 6:21 pm
but like what you mean by "blanks" and wut is the diff between slotted and drilled rotors?
Postby TadS » Fri Oct 27, 2006 6:23 pm
Drum brakes do very little, you can do a rear disc conversion. The pads are equally important to the stopping power of the car. SS brake hoses will also encourage better braking. Slotted rotors clean off the pads to give a clean braking surface, but because of this they eat pads. The drilled ones help prevent gas related fade. It has already been said normal vented rotors have the most surface area, so they do the best for normal driving IMO.
TadS
Postby woa_its_j3ff » Fri Oct 27, 2006 6:31 pm
ah so wut kind of rotors do u recommend for me? since i dont race etc etc. just daily drive.
Postby Mr_Chunks » Fri Oct 27, 2006 6:33 pm
i hear drilled rotors are more fragile
but i got crossdrilled+slotted kuz it looks cool. So far in my experience with them, they grip way better than stock, they have no squeal and they seem to be working just fine. Checking the pads, i found no uneven or unecessary wear, so it seems okay to me.
Mr_Chunks
Postby woa_its_j3ff » Fri Oct 27, 2006 6:37 pm
^ alright good cuz my brakes sqeal lightly when i brake but this is even at like 25 mph.. dont like it' gets annoying (with windows up) ...but would upgraded brakes by brembo work with stock wheels? im assuming so right since Mr_chunks had them on before his rims.
Postby TadS » Fri Oct 27, 2006 6:53 pm
Unless you can get a kit, the rotors are the same size as stock.
TadS
Postby woa_its_j3ff » Fri Oct 27, 2006 8:46 pm
^ oh. i did not know that.. :o . they looked bigger on Mr_chunks car...
Postby s15lara » Fri Oct 27, 2006 8:55 pm
dude, ill explain everything to you and how it works and all tomorrow. ill give you a call. and all the parts that you need/will need i got the hook up for in chicago. ill call you and let you in on the 411.
almost there...what do you think?
s15lara
Postby woa_its_j3ff » Fri Oct 27, 2006 9:05 pm
^ sounds good. call me after 6 tho pls. im at work from 10-6 tomorrow.
Postby s15lara » Fri Oct 27, 2006 9:09 pm
no prob. you got that meet going tomorrow dont you? i doubt it i'll be able to make it cuz for one, my headlights crapped out on me. i need to look into that AGAIN! i must have a short or one of the wires just keeps getting lose cuz it seems to work only when it wants to. ahhhh, had to vent. sorry everyone.
s15lara
Users browsing this forum: Google [Bot] and 19 guests
