SolaraGuy.com • View topic - Problem with the gauges
Postby 2000goldsolara » Wed Nov 01, 2006 9:40 pm
I bought aftermarket white gauges a few years back. Well for some time I have been trouble with it. I'm not exactly sure what the problem is exactly. So whenever I turn my headlights on the gauges will light up for a second or two and then go out. I took a look into the dash and I found that two bulbs are out. I was thinking this was the problem but I was told it could be the fuse? Any help would be appreiated.
Thanks,
2000goldsolara
2000goldsolara
Postby lilm » Wed Nov 01, 2006 9:54 pm
well if the bulbs are out your going to have to change them anyway............so i would do that first if that doesnt work it might be a loose screw in the back of the gauges causing it to shake and let the lights flicker......replace the bulb first then post again if that doesnt fix your problem
lilm
Users browsing this forum: Google [Bot] and 19 guests
