SolaraGuy.com • View topic - 245/40/18 on 18x8, what offset do i need?
Postby hari-bhari » Fri Nov 03, 2006 2:00 pm
Is it ok to run tires this wide. This is what my understanding is now:
-50mm offset wont clear the strut, obviously will clear the fender
-45mm offset and 225 or even 235 width tires usually clear both strut and fender
-35mm offset and 225 width tires requires rolling the fender, the strut would obviously be cleared.
so what I am thinking is that is the tire is 245 width, will it be ok at a 40 offset and with the fender rolled?
hari-bhari
Postby blaK » Fri Nov 03, 2006 5:44 pm
245? omg man you don't that, 235 the most.
blaK
Postby SolaraBlue » Fri Nov 03, 2006 5:56 pm
with 18x8, 40offset is the best.... 225/40's should work fine. buy a tire with a curved sidewall and you shouldnt have to roll your fenders.... am i understanding the question? lol.
my tsw's were 18x8 40 offset with 225/40 tires and i had no rub issues...
Postby hari-bhari » Fri Nov 03, 2006 7:00 pm
no the reason im asking is because the wheels im looking at right now on ebay come with 245/40/18 tires....
so is there any way to make this fit or am i gonna have to dismount them?
hari-bhari
Postby PXLpainter » Fri Nov 03, 2006 7:06 pm
I can't speak for the Gen 1s but I know that 245s with a 30 offset on my Gen 2 rub like hell - until I cut my fenders. Still got a little more to trim this weekend.
So rolling might work with the 40 offset. I think the 245s look/ride excellent if you can squeeze them in there! :D
Postby dominoSLEV6 » Fri Nov 03, 2006 7:23 pm
Dude, I have 245's on the back of my Supra. It will look retarded on a Front drive car with 18's.
I'm not sure if your post was a yes or no question... but,
No.
-chris
dominoSLEV6
Postby GooseXRS » Sat Nov 04, 2006 2:29 pm
rim manufactures say 235 is the widest. But rolled and pulled fenders with 245 should be ok. A little negative camber to tuck in the top. FLUSH. VIP status.
GooseXRS
Postby hari-bhari » Sat Nov 04, 2006 10:26 pm
yea i guess itll be too much trouble. ill try and find em with narrower tires
hari-bhari
