SolaraGuy.com • View topic - check engine light on..
Postby woa_its_j3ff » Fri Nov 03, 2006 10:47 pm
not sure if this goes under aftermarket or just the reg area. but i put it in aftermarket because i think it's related to the intake.
so i got the Injen SRI installed today, it worked perfectly and drove without any issues ever since the install. Then about 45 minutes later the check engine light went on and my buddy with his accord says it did the same thing to his car but later on the light went away.
I know there is nothing wrong with the car but what can I do to have the light go away? (other than something stupid like removing the bulb that lights up the 'check engine' or something along those lines)
Postby unbalancedwood » Fri Nov 03, 2006 10:55 pm
I think ive heard people having this problem before when putting on intakes. Take it to the AutoZone or whatever and have them run a free code check...
unbalancedwood
Postby woa_its_j3ff » Fri Nov 03, 2006 10:56 pm
unbalancedwood wrote:I think ive heard people having this problem before when putting on intakes. Take it to the AutoZone or whatever and have them run a free code check...
what does a code check do.
Postby unbalancedwood » Fri Nov 03, 2006 10:58 pm
Last edited by unbalancedwood on Fri Nov 03, 2006 11:01 pm, edited 1 time in total.
unbalancedwood
Postby Anonymouse » Fri Nov 03, 2006 11:00 pm
woa_its_j3ff wrote:what does a code check do.
Gives you a code that lets you know exactly what is wrong. I've had my check engine light on for 2 years. The OBD scanner indicated the oxygen sensor. I'm running rich and I love it.
'99 SE V6 5 Speed Black, 8000K HIDs top and bottom
TRD Sport Muffler, Eibach Pro-Kit, K&N Drop-In
Anonymouse
Postby woa_its_j3ff » Fri Nov 03, 2006 11:03 pm
dont know. is there a way to fix it? i mean if i bring it to autozone n get the code check .. what do i do after? anyone know where I can or how I can fix this? I dont think my car is having issues since it runs fine. just the light is on.
Postby unbalancedwood » Fri Nov 03, 2006 11:04 pm
Yeah, On Board Diagnostic...
Dosent the check engine light lower your horsepower?
PS, OBDII CODES
http://www.solaraguy.org/viewtopic.php?t=16121
Last edited by unbalancedwood on Fri Nov 03, 2006 11:05 pm, edited 1 time in total.
unbalancedwood
Postby woa_its_j3ff » Fri Nov 03, 2006 11:05 pm
i didnt notice it at all but then again ive had some drama lately so not really paying attention to that.
what's the OBD?
Postby woa_its_j3ff » Fri Nov 03, 2006 11:07 pm
i heard from a fellow sg member that you can disconnect the negative battery terminal and it will go away. [if there is a problem then the light will come back]
Postby unbalancedwood » Fri Nov 03, 2006 11:19 pm
Yes, 20-30mins disconnect to be safe. Ive done this before. My light came on, went to AutoZone and got my code read, unplugged my battery, came back on, ended up getting a new 02 sensor (bank 1, sensor 1). It wouldnt hurt you if you tried resetting it. Just a pain resetting all the clocks...
unbalancedwood
Postby lilm » Mon Nov 06, 2006 11:53 pm
Yes unplugging the battery for a half hour will reset the code but if it comes back on i would head to autozone........when the check engine light comes on the computer KNOWS what the problem is so what you do is drive it to autozone and have them stick a obdII scanner into it thew will then tell you the code and what it means usually if they dont have one that names the code just write it down and search for it here to see what the EXACT problem is might be a maf sensor malf. which would indeed be your intake......or something else
And the limp mode where it lowers your hp is usually because of a blown knock sensor so dont worry about that
lilm
Postby Eye8Pussies » Tue Nov 07, 2006 12:51 am
no need to pull the battery
just pull the efi fuse...saves a lot of headahces- clock/radio/alarm, etc.
Postby dvdchris45 » Tue Nov 07, 2006 12:55 am
my injen sri threw a CEL MONTHS after i had to installed...but it went away after i double checked my connections to the MAF sensor..Also..you may get a CEL if you dont put on your gas cap improperly...did u fill gas recently?
and of course..do what the others told.. just my .02cents
<b>04 Desert Sand V6</b>
<i>Injen + Magnaflow </i>
<i>TRD FSTB + RSB</i>
<i>HID + A/V + iPod</i>
dvdchris45
Postby Jon11582 » Tue Nov 07, 2006 12:16 pm
Go to autozone.
Have them pull the code. (Just tell the guy your check engine light is on, he'll know what to do. Also called ODB-2 or CEL code). He will connect a tool to your car and read the code stored in the car's computer.
Write down the code he pulls.
Ask the guy to clear the code while hes plugged in there.
Drive home.
Put the code in google to find out what it means.
See if it comes back.
Probably as simple as a lose hose or connection. Make sure the hoses and the couplers are all on tight. Or it could be something completely different...which is why you want to pull the code and clear it with the diagnostic tool and not just clear it by disconnecting the battery.
2000 Black Solara SE
Jon11582
