SolaraGuy.com • View topic - air fuel ratio gauge question
Postby woa_its_j3ff » Tue Nov 07, 2006 6:54 pm
ever since i got my air fuel ration installed today it's be going like this..
lean-rich-lean-rich
etc etc..
the needle/dial just does it the entire time unless my foot is off the gas, then it does nothing.
is this normal?
my buddy says it's cuz my intake draws in more air so the needle does that, but im not sure.
any answers/info?
thanks.
Postby Mandarinsolara » Tue Nov 07, 2006 7:01 pm
its pointless unless wideband
Mandarinsolara
Postby woa_its_j3ff » Tue Nov 07, 2006 7:05 pm
^ what do you mean?
Postby DatSRBoi » Tue Nov 07, 2006 7:24 pm
Your friend made a wrong guess...
The gauge you got is a narror band. Its only for show. No go. Thats why its so cheap compare to the real deal. What you see on your gauge is normal.
Again, its only for show.
Postby woa_its_j3ff » Tue Nov 07, 2006 7:35 pm
so nothing is wrong with it? it's just supposed to act like that?
narror brand what?
and the gauge i got isnt like a cheap kind either it's fairly expensive.
Postby Eye8Pussies » Tue Nov 07, 2006 8:16 pm
a narrowband is underestimated....
you can't tune with it, definately not. but it can and WILL tell you if something is wrong though, such as:
running lean during lean condition cel
running rich during knock-sensor retard
Postby woa_its_j3ff » Tue Nov 07, 2006 8:18 pm
^ yeah but the thing is. it keeps sayin "
Lean" rich lean rich .. back forth everytime i accel. only time nothing happens is when my foot isnt touching the gas.
Postby Akfahad » Tue Nov 07, 2006 9:03 pm
From what I've heard A/F gauges are kind of pointless. And from what I've read, what your gauge is doing is normal...Dat was correct.
Postby Eye8Pussies » Tue Nov 07, 2006 9:54 pm
yup...what it's doing is normal....basically the furthest reading is the correct reading...
if it touches green at all, it's going into the rich zone, if it only goes as far as yellow, then it's stoich, if it stays red all the time, you're running lean
and if you run super lean, the narrowband won't read anything at all since it's out of range...that's when you need a wide-band to tell you what's really going on
Postby DatSRBoi » Tue Nov 07, 2006 10:29 pm
Sometime it goes off your gauge too which is normal. Its all good. Nothing to worry about. Just dont tune with that haha or youll blow your car up.
Postby Eye8Pussies » Tue Nov 07, 2006 11:13 pm
^ lol...yup...real quick....haha...
Postby woa_its_j3ff » Wed Nov 08, 2006 6:22 am
^ haha thanks Dats (and everyone else) ill keep that in mind. :)
