SolaraGuy.com • View topic - voltmeter question
voltmeter question
voltmeter question
Postby woa_its_j3ff » Tue Nov 07, 2006 7:48 pm
what exactly does a voltmeter (volt meter gauge do)?
I had this put on my car basically cuz i didnt want just a single gauge on the A-pillar, but i never really got to knwo what the function of it was.
i mean when i start the car the needle stays in one position, it never moves.. is it supposed to move later on if u install more electronics or what?
Postby coldspikee » Tue Nov 07, 2006 8:11 pm
are you for real come on
coldspikee
Postby woa_its_j3ff » Tue Nov 07, 2006 8:19 pm
^simple question. just want an answer. dont got one dont reply. thanks.
Postby lilmike2069 » Tue Nov 07, 2006 8:21 pm
It simply measures the difference in potential parallel to the voltmeter
lilmike2069
Postby woa_its_j3ff » Tue Nov 07, 2006 8:30 pm
^ it doesnt have to do with the battery and wutnot?
i heard that in the mornings when its cold when you start it, the numbers read lower.
voltmeter
Postby Sentinel » Tue Nov 07, 2006 8:46 pm
While the above answer is technically correct, it assumes you know whats what.
Basically: If your car is off you should see ~ 12.5 volts, and once you get it started you should see ~14.5 volts.
Sentinel
Postby woa_its_j3ff » Tue Nov 07, 2006 8:48 pm
when my car is off. it reads 0. the needle just turns off (or however u say it)
when it start it in warm weather like right when it came out of the shop it went to about 12, then moved slightly to the 14 area.
Postby NeFaRiOuS_SLE » Tue Nov 07, 2006 10:52 pm
What is the other gauge? If you have a boost gauge, you should've just gotten the A/F ratio meter (or vice versa); I fail to see too much use for a voltmeter.
