SolaraGuy.com • View topic - Problems with gauges part 2
Postby 2000goldsolara » Wed Nov 08, 2006 12:37 pm
Yeah so i tried getting new bulbs like yall said, and it didnt work. It still goes out after a second of being on. Man I'm thinking of just taking it out. Does anyone know how to do that themselves, I dont want spend money ripping it out when I can do it myself
2000goldsolara
Postby Duffman » Wed Nov 08, 2006 11:21 pm
When you say "White gauges" (had to go hunt down Part 1 to know what was going on), are you referring to the needles, or are you referring to the flat faceplate-like gauge covers that slip over the factory gauges? If it's the slip-on kind, there are no "bulbs" - it's an electroluminescent panel. If it's going out, there's a couple possible reasons why:
1) It's not grounded / powered properly. Check your wiring to make sure it's connected to a secure power source.
2) One of the faceplates isn't connected properly. If I recall correctly (I had a similar set of gauges on my 91 Camry), the amount of power that goes to the gauges is dependant on how many of them are connected. If one or two aren't connected well, it can make the ballast... thing... put more power to the ones that are connected.
3) The power box / ballast thingey is bad. I've yet to see a truly "high quality" set of aftermarket white gauge faceplates for the Toyotas.
Perhaps you get snap some pictures of what the actual unit is, and we can go from there?
2005 Pontiac GTO 6-Speed
2008 Suzuki Bandit 1250 ABS
Duffman
