SolaraGuy.com • View topic - Final prep for suspension install
Postby unbalancedwood » Sun Nov 19, 2006 8:11 pm
Well im planning on working on my car tommarrow, replacing the 109,000 mi struts and springs with some fairly new ones I got from Jon; JMSinMaryland this saturday. Again, thanks a lot man! Im going to rent a spring compressor from one of the auto[x] places in town, a torque wrench from Home Depot or Lowes and buy some pentrating oil and loc tight. Ive read these few articals over and over and i think ive got it down tight. Ive got all the jacks, lifts, etc....
But is there anything im forgetting? Anything you would also add or POINT OUT if it somthing pretty serious? Thanks a lot guys, your worlds of help!
The PDF of everything (torque, etc)
Back Seat Removal
Camry installation walkthru
:popcorn: :popcorn: :popcorn:
unbalancedwood
Postby ThatVietGuy » Sun Nov 19, 2006 8:16 pm
Watch out for the ABS sensor and you're good to go.
ThatVietGuy
Postby Sparticus » Mon Nov 20, 2006 5:27 am
yeah, when you drop the back strut out, the hub will want to go down. There should be a wire connected to the wheel well and 1 bolt holding it there. (10mm i think) take that out so the wheel speed sensor wire doesn't get pulled. Mine did and i have no clue what i'm gonna do about it. Other than that you should be fine. Take the time while the back seats are out to clean it all down really good.
1999 v6 SLE, 5% tint, drilled + slotted rotors, clear corner lights, TRD RSB HAS ARRIVED!!!! WTB: new tokico struts.
Money for Solara = $0 untill after christmas.
Sparticus
Postby lightear » Mon Nov 20, 2006 9:05 am
Do the fronts first. They are much easier to do. As you go through the front ones you'll realize how the brakes will pull down everything when you remove the strut. That gives you the idea why the rear ones would pull the ABS lines.
So, have couple thick useless text books underneath the rear ones or a jack to hold it up.
Other than that, take your time. If the front two takes too long stop for the day and take a break. Don't rush these things. Good luck and have fun.
lightear
Postby ThatVietGuy » Mon Nov 20, 2006 10:09 am
P.S. My install took 7 hours with two people, so I guess you can expect something around there :lol:
ThatVietGuy
Postby Eye8Pussies » Mon Nov 20, 2006 10:27 am
^ 7 hours??? good god....it shouldn't take that long at all....the longest part was compressing the springs with a manual spring compressor
and more important than all the other tools that you listed would be an impact gun
Postby Ruski » Mon Nov 20, 2006 1:36 pm
My install took 8 hours 2 people. its a pain so get a warm place to work, some pizza and prepare yourself.. Also Watch out for the sway bar links.. they are a pain. Had to replace my rear one So be careful
Postby ---CAMRAZY--- » Mon Nov 20, 2006 4:24 pm
I have done 3 solaras in 8 hours in 1 day...... No spring compressors, don't need them...... But then again Just Camrys and Solaras I have probably done over 50.... And that is not naming all other cars and trucks I have lowered since I was 16, and now it has been 12 years since.... Just trying to do our society good.
Back on topic, you will be good.... Be patient, if you have any problems PM me.
Postby lightear » Mon Nov 20, 2006 5:07 pm
PM him even if you don't have problems. I'm sure you have some questions in your mind.
---CAMRAZY--- wrote:I have done 3 solaras in 8 hours in 1 day...... No spring compressors, don't need them...... But then again Just Camrys and Solaras I have probably done over 50.... And that is not naming all other cars and trucks I have lowered since I was 16, and now it has been 12 years since.... Just trying to do our society good.
lightear
Postby SolaraGuy22 » Wed Nov 22, 2006 2:28 pm
Road trip for me when I decide to get my coils :D lol
Man's got skillz
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby unbalancedwood » Sat Dec 09, 2006 8:57 pm
So I finally took started switching out my struts and springs and i came to a stop when i saw the driver side strut mount. If this is problem? I know its suppose to have a cut on both sides, but as you can see theres what look like cuts on the top of each side of the mounts. Whats up with this? Do i need to replace my mounts too?
-Adam
unbalancedwood
Postby hskrsolara » Sat Dec 09, 2006 9:39 pm
I would recommend replacing all strut mounts at the same time as the suspension, as the mounts will fail over time. Might as well replace all 4 of them while you have it all apart.
hskrsolara
Postby anttarz » Sat Dec 09, 2006 10:59 pm
I would also recommend replacing mounts and lower insulators. The front strut mounts tend to wear quickly on solaras.
Be careful with the ABS sensors, my bro ripped one of mine out while removing a strut. Cost me $180.
Spring compressors are not necessary with a little muscle.
anttarz
Postby hskrsolara » Sun Dec 10, 2006 1:04 am
go to autozone for the spring compressors...you get all your rental money back! they make the job much easier! Also, replace the sleeves i.e. strut boots while you have the mounts done.
hskrsolara
Postby PXLpainter » Sun Dec 10, 2006 1:14 am
Yeah - it took me about 3 hours to sit there and drink beers and tequila while I watched Milt do all the damn work!! :D :lol:
