SolaraGuy.com • View topic - anyone got 18x9s?
anyone got 18x9s?
anyone got 18x9s?
Postby hari-bhari » Mon Nov 20, 2006 9:58 am
anyone have 18x9 on their solara? what offset and tire size?
hari-bhari
Postby **PoshPepper** » Mon Nov 20, 2006 10:42 am
I dont think anyone has 9" width on their solara... maybe you can be the first :)
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby ---CAMRAZY--- » Mon Nov 20, 2006 4:26 pm
They fit with the proper offset and slight negative camber depending if you are lowered or not.
Postby SolaraBlue » Mon Nov 20, 2006 4:32 pm
still lookin for rims hari? 18x9 would look bad a**.
Postby Smoothro » Tue Nov 21, 2006 7:12 am
I love my 18x8's. They look pretty aggreassive to me, especially from the back since they are pretty wide. I had to get my rear fenders rolled though, and my fronts scrape sometime if I hit a sudden bump, but then again, I really need to install those struts :(
Smoothro
Postby trdkamuri51o » Tue Nov 21, 2006 7:31 am
mark and me were talkin about it a while back... it might be possible.... roll the fenders and push them out very slightly... i think melodys would be a perfect example of a nice ass rolled fender...maybe just maybe you could. with that...
be the first to do it.. my guess is since a 19x8.5 fits on a 33mm offset (with a 5mm spacer in rear)
a 28mm offset or so (ask kenny) might just work.. and i say MIGHT
trdkamuri51o
Postby ---CAMRAZY--- » Tue Nov 21, 2006 11:07 am
Like I said IT WILL WORK.
Postby rollaevo99 » Tue Nov 21, 2006 11:10 am
^^^ listen to the pro..... :drinking:
Postby indiglosolara » Tue Nov 21, 2006 11:28 am
It will work if you got the money to play...
you can do 18x9 with a 30mm offset with negative maybe 3 degree camber and some screeched tires. Probably a 235/35 series tire..
Roll the hell or cut
Anything will work with the right amount of money..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby **PoshPepper** » Tue Nov 21, 2006 11:40 am
It wont cost that much to cut fenders... so I dont really think money is an issue for making them fit...
He isnt super low... so I would think rolling or cutting the fenders would do the trick along with the correct offset, tire size and camber... really shouldnt be that tough if done right (and that is of course the key)...
Milt's OTHER ride
**PoshPepper**
Postby ---CAMRAZY--- » Tue Nov 21, 2006 11:48 am
The only issue when it comes to money are the rims.... Negative camber depending on how low you really are.... Cutting or rolling the fenders is a given...
