SolaraGuy.com • View topic - 35 offset, bad for hub bearings?
Postby hari-bhari » Thu Nov 30, 2006 11:28 am
I was going to run my new wheels (18x8) at 35 offset and roll my fenders. However, when I talked to the guy at NAPA, he said 35 offset will work, but it will put more strain on the hub bearings due to the wheels being further out. As a result, they will wear out faster and need to be replaced. Is this true, and has anyone with 35mm offset had trouble? Id rather stick with 42mm and keep my car safe.
hari-bhari
Postby CASTRO » Thu Nov 30, 2006 11:32 am
i think big wheels in general will wear out your bearings faster. heavier wheels/rims, stiffer suspension, etc is bad since its not dead center or near the specs of stock.
Personally, I've had both right side wheel bearings go bad on me. it cost close to 600+ to replace/repair both.
CASTRO
Postby **PoshPepper** » Thu Nov 30, 2006 11:33 am
Ummm... is he saying that all 35 offsets are bad, or that 35 offset is bad for the Solara? Because stock G35 weels are 30 offset... :-?
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby DatSRBoi » Thu Nov 30, 2006 11:37 am
CASTRO wrote:i think big wheels in general will wear out your bearings faster. heavier wheels/rims, stiffer suspension, etc is bad since its not dead center or near the specs of stock.
NOO man we all know why your bearing went bad. Stop beating all those cars at the track ahah.
Postby hari-bhari » Thu Nov 30, 2006 11:42 am
35 offset is bad for us because it puts the wheel further out from the hub, this in turn induces more torque and strain on the bearing. im wondering if this is sufficient enough to make a difference?
hari-bhari
Postby ---CAMRAZY--- » Thu Nov 30, 2006 12:38 pm
The offset doesn't wear out the bearings.... the Weight of the wheels do.
And I ran a 18x8 with a 30 offset on my first solara, never had a problem.
Postby GooseXRS » Thu Nov 30, 2006 1:31 pm
I am running 35 offset and I dont have any problems that werent already there.
"The defense department regrets to inform you that your sons are dead because they were stupid. "
- Goose
GooseXRS
Users browsing this forum: Google [Bot] and 19 guests
