SolaraGuy.com • View topic - After an hour of searching..
Postby Mr_Chunks » Fri Dec 01, 2006 1:31 am
I still didnt get a definitive answer.
How do you take the entire center console assembly ( all the way from the console part itself to the plastic over the shiftgate ) out. I been able to take out the plasic over the shiftgate to expose the bare shiftgate and shifter, but i cant figure out how to take out my center console completely.
Also
I know manual temp solaras have bulbs in there that you can change but for Automatic climate control solaras ( SLEs ) can we change the nasty green color of that screen and those buttons?
I hope someone can answer these questions.
Mr_Chunks
Postby ThatVietGuy » Fri Dec 01, 2006 1:41 am
For the center console (with the clock and stuff), pull out the ashtray and start pulling the inside of where the ashtray was. Everything should pop out with relative ease.
Everything else, though, I don't know.
ThatVietGuy
Postby Mr_Chunks » Fri Dec 01, 2006 11:44 am
actually i was talkin bout the center console as in the armrest =P but i figured it out
inside armrest comparment under carpet theres 2 bolts, take them out
pry up plastic around shiftgate itll pop up
unscrew 2 phillips head screws connecting console to shiftgate
lift out
heh that was easy
:oops:
Mr_Chunks
Postby Ruski » Fri Dec 01, 2006 12:13 pm
yeap i as just about to type that but pc Shut down b/c off a storm
Postby PXLpainter » Fri Dec 01, 2006 12:32 pm
Yeah - even though we give people a hard time about using the SEARCH here on SG - you have to admit that it TOTALLY SUX!! :x
Good luck...
Postby Mr_Chunks » Sat Dec 02, 2006 12:34 am
yes but i found a lighting guide that jon wrote
and im gonna try it out soon
wish me luck. I have really bad luck with car interiors
( milt knows whats up ) HAHAHA -_-''
Mr_Chunks
