SolaraGuy.com • View topic - 2001 LS 430 Brakes
2001 LS 430 Brakes
2001 LS 430 Brakes
Postby GooseXRS » Wed Dec 06, 2006 10:26 pm
I was just curious... My friend just bought a LS430 and is getting a set of stoptechs. Now would it be possible to use his stock brakes. It would be cool because they would look stock but would be way better. Sleeper... :evilbat:
Let me know if you know.
Thanks
Take Care
Androo
"The defense department regrets to inform you that your sons are dead because they were stupid. "
- Goose
GooseXRS
Postby jhenty » Wed Dec 06, 2006 10:37 pm
i imagine it would be custom. are those brakes even much better? I mean i would imagine they may be bigger but its a much bigger car.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby GooseXRS » Wed Dec 06, 2006 11:40 pm
Well they are four pot calipers up front so they are bigger. And the rotors are bigger. I say if its good enough for tom's celsior with appr350hp, Its good enough for a car thats atleast 1000lbs lighter. Just my logic. It shouldnt be hard to make them work. Correct me if Im wrong.
Thanks
Take Care
Androo
- Goose
GooseXRS
Postby Eye8Pussies » Thu Dec 07, 2006 12:28 am
custom caliper brackets to mount the rotors
the calipers won't work
Postby GooseXRS » Thu Dec 07, 2006 1:13 am
Eye8Pussies wrote:custom caliper brackets to mount the rotors
Could you elaborate?
- Goose
GooseXRS
Postby SleeperSolara » Thu Dec 07, 2006 7:51 am
You would need custom brake caliper brackets.
Cause a former member made some custom brake brackets for our cars to use Supra TT rotors.
But we would still use our 1 pot caliper.....
But if you do or are able to figure how to use the LS430 calipers let us know. :D
Postby Jon11582 » Thu Dec 07, 2006 10:55 am
SleeperSolara wrote:You would need custom brake caliper brackets.
Not the same thing, that would still use our stock brake pads. He would also have to change the caliper to bring over the pad and the 4pot configuration.
Also if you go from a 1 pot to a 4 pot, I'd imagine you would need a different master cylinder.
In short, whatever steps he uses to put the stop tech in his car should probably be the same to put the LS brakes in your car. Its definitly possible, but probably an advanced job.
2000 Black Solara SE
Jon11582
Postby GooseXRS » Thu Dec 07, 2006 12:50 pm
Thanks Guys
- Goose
GooseXRS
Postby SleeperSolara » Thu Dec 07, 2006 4:10 pm
Jon11582 wrote:Not the same thing, that would still use our stock brake pads. He would also have to change the caliper to bring over the pad and the 4pot configuration.
That true too.
Postby ThatVietGuy » Thu Dec 07, 2006 8:23 pm
Man, this is so much easier with S14's and 300ZX TT calipers: cut off the shield and bolt on :lol:
ThatVietGuy
Postby GooseXRS » Fri Dec 08, 2006 12:32 am
ThatVietGuy wrote:Man, this is so much easier with S14's and 300ZX TT calipers: cut off the shield and bolt on :lol:
I know I have gtr n1 brakes on my s13 and my brother has z32tt brakes on his. 20 minute conversion.
- Goose
GooseXRS
Postby Mr_Chunks » Fri Dec 08, 2006 8:27 pm
andrew just get yourself a big brake kit
its way easier :-?
Mr_Chunks
Postby GooseXRS » Sat Dec 09, 2006 4:22 am
Mr_Chunks wrote:andrew just get yourself a big brake kit
its way easier :-?
Easier isnt always better... Besides its not the destination. its the journey.
Also I rock the 16's I cant have huge calipers and rotors.
Thanks
I will consider it.
How much is a big brake kit for our cars B.T.W.?
- Goose
GooseXRS
Postby Eye8Pussies » Sat Dec 09, 2006 11:33 am
1200USD I think it was, from stoptech
Postby Jon11582 » Sat Dec 09, 2006 12:34 pm
its way easier :-?
Doesn't a BBK just include the same type of parts as if you took the entire brake system off another car? Which means its the same installation procedure. The only thing I think would be different is if they provide special brackets for mounting the new hardware to your existing hardware.
With a little research, found that LS430 Front brakes are 12.4" and front Camry/Solara brakes are 10.7". For comparison, Supra TT rotors are 12.8" and the Stoptech BBK is 13"
What's all this mean? Assuming the LS430 calipers are the same thickness as ours, front rotors will require at least a 17" rim.
Jon11582
Users browsing this forum: Google [Bot] and 73 guests
