SolaraGuy.com • View topic - 19" tire size question
Postby facevedo17 » Thu Dec 14, 2006 4:08 pm
hello peeps ...quick question most of us are using 235/35 on our 19" wheels ...had nybody use 225/40 on theirs ...?????
facevedo17
Re: 19" tire size question
Postby indiglosolara » Thu Dec 14, 2006 4:27 pm
facevedo17 wrote:hello peeps ...quick question most of us are using 235/35 on our 19" wheels ...had nybody use 225/40 on theirs ...?????
It really depends on the width of the wheel.
When I had my 19x7.5" wheels I was running 225/35 Falken St115's.
But with 8.5" or even 8" I would run 235/35..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby facevedo17 » Fri Dec 15, 2006 5:26 pm
yeah thats true about the width butim talking about the height most 19 are 35/ Im asking has anyone gone 40
facevedo17
Postby indiglosolara » Fri Dec 15, 2006 5:45 pm
If you want to stick closest to stock diameter then 235/35 is as close its going to get..
or 225/35 which is only a little shorter...
using a 40 on 19's is going to make your wheel taller and throw off the speedo and may also cause rubbing issues...
This is in term of using the wheels on a gen 1 or 1.5. Gen 2's can use 40 ot 45 on a 19" and be fine since they some with a larger wheels diameter from the factory..
indiglosolara
Solara 2 xB
Solara 2 xB
Postby facevedo17 » Fri Dec 15, 2006 7:47 pm
damn thats sucksssssss...there goes my 19" well thanks nways Ill stick with 18 " for now
facevedo17
