SolaraGuy.com • View topic - ebay headers
ebay headers
ebay headers
Postby Dawgz » Sun Dec 31, 2006 2:50 pm
are they good?
the ones listed like this
http://cgi.ebay.com/ebaymotors/Header-T ... enameZWDVW
and others...
Does anyone have them on? would i run into problems if i baught them and put them on?
headers
Postby NRDriver » Sun Dec 31, 2006 4:49 pm
i doubt anyone has the unless they are the megan headers. they look nice and are cheap. i would buy them if i had the money. i wonder if the y pipe comes with the setup. if so, then its seems that they are a bit toooo cheap
NRDriver
Postby Dawgz » Mon Jan 01, 2007 1:38 am
anyone know if this is a direct bolt on?
is it safe to use?
And should i even bother with it since i dont have a supercharger? Would i see any gains on a stock v6?
Postby trd628 » Mon Jan 01, 2007 8:45 pm
i have the same question, has anyone heard anything about these headers? brand name? sounds almost too good to be true to me. good deal if it is might endup buying them though?
trd628
Postby hskrsolara » Mon Jan 01, 2007 9:15 pm
They say that they are dyno tested, but I do not see any results on the listing...unless the gains are proven, I couldn't justify the money or the labor to install them.
hskrsolara
Postby jhenty » Mon Jan 01, 2007 10:36 pm
I have a set, not installed yet, but they seem quality to me. The welds are good but im no expert on the thickness of the steel used so I cant say about that area but i know the welds look decent. I will be installing them soon and everything looks fine so far.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby trd628 » Mon Jan 01, 2007 11:36 pm
how hard is it to install the back header on our cars? everything else is a sinch. would it be worth it to have someone else install them?
trd628
Postby jhenty » Tue Jan 02, 2007 12:29 pm
the back is a little hard, but if you can do the rest you can probably do it no problem. Its a matter of trying to manuver the part around with limited space. Also I had trouble when trying to take off the manifold in the front of the car because one bolt in the corner is tough to get out without the right comnbinations of extensions and sockets. Other than that the only thing that can make it difficult is rusty bolts.
1990 BMW 535i
jhenty
Postby Dawgz » Tue Jan 02, 2007 12:34 pm
hey Jhenty, can you please post after you install them about the diffrence you feel from the stock manifolds?
If it goes well for you, ill buy a set.
Postby trd628 » Tue Jan 02, 2007 2:15 pm
just bought a st post pics and how the install goes once I get them
trd628
pipes
Postby NRDriver » Tue Jan 02, 2007 7:06 pm
just buy it you cheap dastard. LOL. i know you've been lookin into a supercharger. these will be worth it when you get one. these are cheap for our cars. labor to put these on would be ridiculous. suk it up and do it yourself
NRDriver
Postby campfire9 » Tue Jan 02, 2007 9:20 pm
It looks to me like the exhaust from the rear pipe still has to make a 180 degree turn with these headers just like our stock exhaust pipes. Seems to me that if you want to get the most out of the header system you would neet to change the direction of the rear pipe to have a smoother flow into the main pipe going into the cat and muffler. Have the rear exhaust go into a "y" pipe like some people are doing with their stock exhaust system. Otherwise I don't see any advantage to spending the money on these pipes especially with no dyno printout.
The rear pipe on my stock system goes into a "y" pipe I had made at a muffler shop and really works well.
campfire9
Re: pipes
Postby Dawgz » Tue Jan 02, 2007 9:37 pm
NRDriver wrote:just buy it you cheap dastard. LOL. i know you've been lookin into a supercharger. these will be worth it when you get one. these are cheap for our cars. labor to put these on would be ridiculous. suk it up and do it yourself
not a situation of being cheap, its the fact that i dont want this crap falling off while im driving....
Postby hskrsolara » Tue Jan 02, 2007 9:50 pm
campfire9 wrote:It looks to me like the exhaust from the rear pipe still has to make a 180 degree turn with these headers just like our stock exhaust pipes. Seems to me that if you want to get the most out of the header system you would neet to change the direction of the rear pipe to have a smoother flow into the main pipe going into the cat and muffler. Have the rear exhaust go into a "y" pipe like some people are doing with their stock exhaust system. Otherwise I don't see any advantage to spending the money on these pipes especially with no dyno printout.
exactly why I was thinking...why buy an oem replacement, cause without proven dyno results, these headers/pipe are worthless, IMHO.
hskrsolara
Postby SpikedMantis » Thu Jan 04, 2007 11:22 am
I emailed the seller a few Q's, and this is the response:
hi,
the pictures shows all parts included in the package. we do not have dyno info, only factory has it. its importanted directly from asia factory which makes alot of stainless steel header. so it will be no brand.
Having any question, simply email and let us know.
thank you
www.Ebstores.us
This is the space where I should write something witty or clever, hoping to show some personality.
SpikedMantis
