SolaraGuy.com • View topic - problem with a stabilizer link bar
Postby unbalancedwood » Tue Jan 09, 2007 9:15 am
Okay, so i stripped the bolt on my stock one, but the boot was cut and leaking greese anyways. Cost me $48 for a new one, call me stupid :oops:
But heres my problem, the new one dosen't use the allen wrench technique, you hold one side with a 19mm wrench and tighten the bolt on the other. But with the wrench's I have they are too thick and dont allow the bolt to fully tighten. I tried calling around for those thin wrench's that are 2-3mm but no one had them.
I got some 'almost heavy duty' long nose pliers, anyone with other ideas?
unbalancedwood
special tool
Postby Sentinel » Tue Jan 09, 2007 9:44 am
go buy a cheap wrench and grind it down if you can't find one.
Sentinel
Postby unbalancedwood » Tue Jan 09, 2007 9:50 am
grind it with what? i was thinkin abotu that
unbalancedwood
Postby SleeperSolara » Tue Jan 09, 2007 10:04 am
I think you got the wrong sway bar end links.
Postby Midias » Tue Jan 09, 2007 10:07 am
Buy a cheap wrench and grind it thin on a bench grinder.
Postby unbalancedwood » Tue Jan 09, 2007 10:31 am
Sleeper - im pretty sure its the same, checked with advanceauto and here http://www.amazon.com/TRW-18284-Sway-Ba ... automotive
It fits perfect, but tightening it is the difficult thing. I'm at college, far away from my sanders and anyone who would have one. I dont know what to do...
unbalancedwood
Postby Midias » Tue Jan 09, 2007 10:55 am
needle nose vice grips then?
Postby unbalancedwood » Tue Jan 09, 2007 3:56 pm
the vise grips dont work they wont hold it in place. if i were to get a cheap 19mm wrench how would i go about sanding it down...without a machine? Thanks for the ideas!
unbalancedwood
Postby Midias » Tue Jan 09, 2007 4:14 pm
unbalancedwood wrote:the vise grips dont work they wont hold it in place. if i were to get a cheap 19mm wrench how would i go about sanding it down...without a machine? Thanks for the ideas!
I file and a lot of free time.
Or check around and see if your school has a shop where you can do it. I know at RIT the mechanical engineering dept could do it easy.
