SolaraGuy.com • View topic - Please read, fuel delivery question
Postby richt1271 » Tue Mar 25, 2003 12:53 pm
i just recently installed my supercharger on 2001 solara v6 manual with greddy evo and injen intake.
i also ordered apexi s-afc II jdm and 2.9'' pulley magnecor wires and denso spark plugs.... my question is: Do i absolutely have to get fuel pressure regulator and fuel injectors...or 5.5 psi will be ok with AFC II. and also..does anyone know if its possible to install the rear spark plugs with a s/c installed? i read that it was impossible...does that mean the s/c has to be taken out?
thanks guys.
richt1271
Postby happy_aggies » Tue Mar 25, 2003 1:17 pm
http://www.zer0.info/solaraguy/viewtopic.php?t=1976
Should answer ur Q. :D
Abt. the plugs, yup it's possible but it's pain in the a*s.
happy_aggies
Re: Please read, fuel delivery question
Postby Flipside909 » Tue Mar 25, 2003 3:43 pm
richt1271 wrote:does anyone know if its possible to install the rear spark plugs with a s/c installed? i read that it was impossible...does that mean the s/c has to be taken out?
thanks guys.
Wherever you read that is wrong. Because it has been done before quite a few times. You just need slim hands and plenty of extensions to get to them. The easiest way will obviously be to remove the S/C.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Yanks0114 » Tue Mar 25, 2003 4:41 pm
thanks guys.
It can be done, but it was easiest to unbolt the sc. You don't need to completely remove it, just unbolt it so you have some more room to work with
Postby richt1271 » Tue Mar 25, 2003 5:23 pm
thanks guys for responding...but the main question im trying to figure out is....... :roll:
quote/ my question is: Do i absolutely have to get fuel pressure regulator and fuel injectors...or 5.5 psi will be ok with AFC II.
richt1271
Postby Flipside909 » Tue Mar 25, 2003 5:33 pm
S-AFC is fine. SAFC II is not out yet...so don't look forward to that until it's released in the US.
www.clublexus.com
Flipside909
Postby richt1271 » Tue Mar 25, 2003 5:51 pm
thanks.
flip: i already purchased apexi s-afc II JDM version
heres link below on ebay.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33596
i got mine for $300
the shop says they will be able to install it even if its in japanese...should be no problem..the interface is all english, just instruction manual is japanese.
richt1271
Postby Yanks0114 » Tue Mar 25, 2003 6:55 pm
richt1271 wrote:thanks.
i got mine for $300
Its not so much of a problem of getting the unit, but the bigger problem is few shops have worked with it yet and therefore a lot of people have been turned away. Im personally waiting for the SAFC II to be released as the US version so my local shop can get some experience with it instead of making me the guinea pig at $110 per hour
Users browsing this forum: Google [Bot] and 46 guests
