SolaraGuy.com • View topic - HEEEEELP!
HEEEEELP!
HEEEEELP!
Postby Solara916 » Tue Mar 25, 2003 5:35 pm
I'm still having the same problem with and indicator light.
It's not the BRAKE indicator light, its the picture of the car...with the lines coming out of the brake lights. I checked my brake fluid, and it's totally full. I'm not having any problems with my brakes, but I don't really know how to check if they are low or anything. Someone please help...i don't want to have to take my car in and pay someone big $$ to check something that i can fix myself.
I just recently installed some subs, could that be affecting the indicator light?
Also....
Lately...my accelorator has been sticking. Has anyone else had this problem? If so...can you help me out in trying to fix it?
Thanks in advanced.
Solara916
Postby Yanks0114 » Tue Mar 25, 2003 6:58 pm
The light you described is there to alert you if a bulb is dead. Make sure to test all the bulbs. Sometimes it'll come on for no reason, but usually it is because a bulb is either dead or going dead.
What do you mean the accelorator is sticking?
Re: HEEEEELP!
Postby NASTY » Wed Mar 26, 2003 8:33 am
SactoSolara wrote:Lately...my accelorator has been sticking. Has anyone else had this problem? If so...can you help me out in trying to fix it?
wow thats scary!
i think he means its sticking to the floor?
'01 SLE V6
NASTY
Postby DavPak » Wed Mar 26, 2003 10:22 am
i once saw a '99 camry with an acorn pinning the throttle cable in the full throttle position! now THAT must have been scary!
'02 Solara S/C'ed V6 5-spd
DavPak
Re: HEEEEELP!
Postby Flipside909 » Thu Mar 27, 2003 8:36 am
SactoSolara wrote:I'm still having the same problem with and indicator light.
Thanks in advanced.
Okay your light bulb malfucntion indicator light (amber color located on the far left of the dash) is the one that's coming on? If that's the case, one of your brake lights are out. 3157 is what you need. I had to replace my left brake light bulb since that stupid malfunction indicator came on during my drive to NorCal from LA yesterday morning.
As for your accelerator sticking, check under the hood to see if theres any debris covering the throttle cable and the throttle pivot.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Guest » Thu Mar 27, 2003 9:50 am
If you have the V6 there is a TSB on the throttle cable sticking. The recommend proceedure is a new one.
Guest
Thanks
Postby Solara916 » Thu Mar 27, 2003 1:41 pm
Thanks for the responses...
Flipside: It is the indicator light that you are talking about. When it first came on, the first thing i did was check if any of the bulbs went out. I tested while my foot was on the brake and when it wasn't. All the bulbs seem to be working though. I'll check the throttle cable and the throttle pivot when i go move my car in about 2 hours, but i don't think it has to do with that. But then again, i have been wrong about a lot of things. :lol:
NASTY: My accelorator isn't sticking to the floor. When i am accelorating from a full stop, sometimes it'll stick and all i have to do is put more pressure on it, but it makes the car rev higher than i want it to when coming from that full stop.
THanks guys. I'll let you know what happens.
Solara916
Users browsing this forum: Google [Bot] and 48 guests
