SolaraGuy.com • View topic - need some help with the ecu
Postby MonkieX » Wed Mar 26, 2003 5:42 pm
I need a pinout dio for the ECU, one that would get a AFR, or AFC to work can anyone get this info?
MonkieX
Re: need some help with the ecu
Postby Flipside909 » Thu Mar 27, 2003 8:29 am
MonkieX wrote:I need a pinout dio for the ECU, one that would get a AFR, or AFC to work can anyone get this info?
You can't use an AFR with the Solara. S-AFC you can. Rod (Bigflyjet) had the pinout info for the S-AFC, BUT he got activated active duty to the Persian Gulf since he's an Officer in the AF Reserves.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Guest » Thu Mar 27, 2003 3:52 pm
damn
Guest
Postby happy_aggies » Thu Mar 27, 2003 4:06 pm
What is a pinout info? Is it a ECU diagram?
happy_aggies
Postby Flipside909 » Fri Mar 28, 2003 12:35 am
happy_aggies wrote:What is a pinout info? Is it a ECU diagram?
Pinout info is for the wiring diagram for the leads into the ecu.
www.clublexus.com
Flipside909
Users browsing this forum: Google [Bot] and 43 guests
