SolaraGuy.com • View topic - Any Engine Rebuild tips...
Postby Ian » Tue Jan 30, 2007 6:18 pm
As I have fried a piston ring, my engine will require a rebuild. I decided to have it rebuilt instead of swapping, buying a new one, or getting another car.
Seeing as how some of you have rebuilt your engines, some to a great degree, I wanted to know if you had any tips that will improve the engine a little. What I mean is, is there a piston, ring, etc. that is a little better than stock that I can use. I'm not trying to do a super makeover as some have done, just a simple rebuild with minor upgrades if possible.
Thanks
Ian
Postby woa_its_j3ff » Tue Jan 30, 2007 6:21 pm
just remember solaras have weak internals. so strengthen those :D
Postby orlin03 » Tue Jan 30, 2007 7:18 pm
This is where the fun is at: searching for parts, finding what's out there, and coming up with a budget. Use the search engine and see what's out there! A few tips that work with any engine: use the best rod bolts you can afford, use the best rings you can afford, and find a good machinist to refresh your heads. Always use new head bolts. Take the block to the machinist right away (or measure everything yourself) to see if you need to turn down the crank for oversized bearings or replace/overbore the pistons. Check the deck and the head surface for trueness, as they could need a shaving (and usually do). The factory clearances are ok, so if they are met, your fine; if not, you're going to be replacing things anyway, so nows the time to consider upgrades if you're so inclined.
Chose a ring with a coating, such as plasma-moly, for better protection, longer life, and more performance; they withstand heat better and can run tighter tolerances, which can keep more combustion pressure in the chamber for more power. If you're going to replace pistons, Forged pistons, like those from Wiseco, are good for boost, and are very durable, but not necassary; if you get them, you can usually chose your compression ratio, and they will tell you what should work, but it will be up to you to check all final clearances. Remember that whatever had to be removed from the decks must be calculated into compression ratios now. Let us know what all you need to replace, and what you will be keeping!
The best place to spend a few extra bucks is on the heads... I mentioned in another post yesterday about the new March issue of import tuner's article on head work; I always swear by a well modified head! Get a five angle valve job, and simply clean up the castings yourself with a dremel, and you will see gains; gasket match the intake ports (instal the gasket, draw it on the head, and remove material), and port the passages, and you will see a huge difference- just don't go nuts. Mild is the way to go, as you can expect payoffs throughout the rpm range with mild alterations. Then, of course, there are cams to consider- again, a slight difference can be the most rewarding. Also, again, tell the cam supplier what type of piston/compression you will be running; if you're going big on compression, you will need different valve timing to avoid contact.
BTW, how did you fry the rings?
orlin03
Postby SleeperSolara » Wed Jan 31, 2007 7:39 am
woa_its_j3ff wrote:just remember solaras have weak internals. so strengthen those :D
Actually our engine's pistons, rods, and crank are pretty strong if i'm right.
It's just the heads and tranny.
Postby woa_its_j3ff » Wed Jan 31, 2007 8:12 am
really? i heard from many people on this forum that they were the weakest part of the solara.
http://www.solaraguy.org/viewtopic.php? ... =internals
PDX SuperSolara wrote:The weakest part of the 1mz is the pistons, the ring lands are always the first thing to go. Properly built and tuned however prevents problems. I would lower compression to 9.2 which allows more boost. I am running 8 psi with a proper fuel delivery system with rising fuel pressure to compensate for boost. Through an automatic I am running 275 hp at the front tires which equates to around 330 at the crank. The rods and crank are pretty strong, but the next weak link I would guess is the block. It is aluminum with liners which doesn't like too much abuse.
Postby Ian » Wed Jan 31, 2007 12:48 pm
Thanks for the insight. I will search more. I thought maybe there was a list of simple plug and play parts that others have used already. I'll keep searching.
orlin03, I'm running 6lbs. of boost, and I never tuned my car, so I've probably been lean for a while. I've been running it like this for a couple of years and it caught up to me. Shame on me.
So, I will do it right this time and have it immediately tuned after the rebuild.
Ian
parts
Postby trd4life » Thu Feb 01, 2007 4:06 pm
I've built a few mondified 1mz/3mz engine in my day if you need help sourcing parts send me a pm.
Postby ---CAMRAZY--- » Thu Feb 01, 2007 4:56 pm
Go look for Glok over on TN and PM him.... He knows whats up. Also Tony The Tiger, only pm him if you are serious though.
