SolaraGuy.com • View topic - CAI best variant - no problems with usage
Postby Russian Guy » Thu Mar 27, 2003 12:45 pm
Pictures are not for our Solaras, but principle is the same 8)
:lol:
1MZ-FE TRD S/C. 2 BLITZ NUR Spec mufflers. SPA Boost/Fuel + Revotec water/oil/volt gauges. BLITZ Powermeter ID III, Denso IK 22 Iridium, TRD brake lines, TRD rear sway bar, fuel pump upgrade
Russian Guy
Postby Peter » Thu Mar 27, 2003 1:05 pm
looks a little cheesy, kinda ricey, but hey, it could work
Peter's "Black Sheep"
Visit Black Sheep
Peter
Postby _nkx1 » Thu Mar 27, 2003 1:52 pm
That seems like a good idea in theory, but in it's actual application, I don't know if it would really work. The main caveat of the air filter portion mounted in the engine compartment is that when stopped, the intake sucks up hot air from the engine. Although the heat shield on the model you show probably helps a little, I don't think the air tube would help much at all. The reason is that there's nothing that will force cold air from outside the engine department through the tube and into the air filter while stopped. So imo, it's basically the same as not having the tube when you're stopped. It might help a little while you're driving, but when you're driving, cold air enters the engine anyway, such as the through grill and other places. But it is an interesting sort of contraption.
_nkx1
Postby Jackass-Jeff » Thu Mar 27, 2003 2:35 pm
there's no force pushing air into the intake... it's just the force the engine uses to suck it in... it would actually become a restricting factor (defeats the purpose of the intake itself). However, if you could get the tube to aim into the filter (instead of the little 'compartment') it should help... good find though :D my friend made a PVC PIPE CAI for his 89 Corolla... who knows if it has gains... but it's a CAI nonetheless :P
1GR-FE ftw!
Jackass-Jeff
Postby Jaimster » Thu Mar 27, 2003 8:26 pm
One thing! The engine is still hot, and a little sun shade will not make heat go away from that area! :-?
Jaimster
Postby Flipside909 » Fri Mar 28, 2003 12:34 am
That design is pointless because your stock airbox is routed the exact same way. Having that "shield" is useless because hot air will get drawn through the cracks when the hood is closed down. And because the hood has cross braces, that shield is not gonna properly seal out the hot air. So really the design is creative but pointless.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Users browsing this forum: Google [Bot] and 44 guests
