SolaraGuy.com • View topic - Major problem in Solaras
Postby LifeguardSLE V6 » Thu Mar 27, 2003 7:40 pm
As I was discussing the idea of a supercharger with my parents, they found this from Toyota Motor Corp.
3.3 million Toyota engines built from 1996 to 2001 have a sludge buildup that can ruin the engine. This affects 1MZ-FE and 5SFE between July 96 and July 01. So for now, the warranty on the car is extended to cover eight years from the date of purchase with unlimited miles driven.
I wasn't sure if anyone had already heard of this, but with that sort of problem, I wouldn't think all the money for a supercharger would be a wise investment.
1999 Solara SLE......Lowered courtesy of Eibach and Tokico.
I put the PRO in procrastination!
LifeguardSLE V6
Postby Jaimster » Thu Mar 27, 2003 8:22 pm
Very old news! :roll:
Jaimster
Postby Jackass-Jeff » Thu Mar 27, 2003 11:46 pm
if you have sludging and have your service records, they will replace your engine or something... use the SEARCH and find the old post on it...
1GR-FE ftw!
Jackass-Jeff
umm
Postby xXsolaraXx » Thu Mar 27, 2003 11:52 pm
umm..whats sludging?
moe
xXsolaraXx
Re: umm
Postby Flipside909 » Fri Mar 28, 2003 12:30 am
xXsolaraXx wrote:umm..whats sludging?
moe
When oil is not changed on a regular basis, oil will start "gelling" or thicken up and stick to the engine's crank pistons and etc. Contaminants in the oil cause a buildup and eventually causes problems in the long run. The only fix is a rebuild. That's why its best to change oil on a regular basis (every 3 to 4k miles is best) and keep record of receipts for each oil change.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Re: Major problem in Solaras
Postby DavPak » Fri Mar 28, 2003 7:24 am
LifeguardSLE V6 wrote:So for now, the warranty on the car is extended to cover eight years from the date of purchase with unlimited miles driven.
that's the warranty on sludging. not the powertrain warranty. powertrain is still 5yr/60K.
and not, they don't replace the engine. they pull it completely apart and clean all the sludge out.
'02 Solara S/C'ed V6 5-spd
DavPak
Postby Yanks0114 » Fri Mar 28, 2003 12:00 pm
Its really not toyotas defect, its just ignorant poeple dont know that cars need both oil AND gas. What a crazy concept. Stick to an oil change every 3-4 months or 3-4k miles, whatever come first and you'll be fine :D
Users browsing this forum: No registered users and 90 guests
