SolaraGuy.com • View topic - JDM BLACK DIAMOND HEAD LIGHTS SUGGESTIONS????
Postby nemoxfishy » Mon Feb 05, 2007 11:35 pm
Im looking for black housing head lights and i came across this on ebay....
http://cgi.ebay.ca/99-00-01-TOYOTA-SOLA ... dZViewItem
Has anyone bought or seen these before??? Im planning on buying these.... any suggestions??? Does anyone know if these fit perfectly?? and do they use the same light bulbs as the stock ones????
nemoxfishy
Postby thealkimo » Mon Feb 05, 2007 11:39 pm
good fitment and you can use stock bulbs...
thealkimo
Postby boneezy » Tue Feb 06, 2007 9:43 am
those pictures are confusing. do they come with corner lamps too? i know the title says headlights, but why have the corner lamps in there too unless they were selling it with the heads
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby nemoxfishy » Tue Feb 06, 2007 4:57 pm
i think its one piece .... the corners are attached to the headlamp ....
am i correct ?? does anyone noe ?
nemoxfishy
Postby MCOjerry » Tue Feb 06, 2007 5:03 pm
Why does it say for show/off road only?
Postby solaraN8 » Tue Feb 06, 2007 5:27 pm
cause they know that the light output isnt as good as stock
New Car, 2003 IS300 5mt
solaraN8
Postby MCOjerry » Tue Feb 06, 2007 5:42 pm
^^thanks...was just curious.
Postby krook » Tue Feb 06, 2007 6:09 pm
nemoxfishy wrote:i think its one piece .... the corners are attached to the headlamp ....
i'm pretty sure it's NOT. have you ever tried taking out the headlights???? there's no way you could get them back in if it were ONE whole piece with the corner lights.
why don't you just ask the seller....? :/
krook
Postby xcgames » Wed Feb 07, 2007 2:10 am
I actually bought these lights for my retrofit.
the headlight is not one piece, the side lamps are separate, and the sides also comes with bulbs.
as far as quality is concerned, these lights sucks. The set i received cannot adjust upwards (the screw on the side of the headlight that adjust vertical orientation does not move fully up) so the entire beam points maybe 20ft away from the car, making the low beam essentially fog.
in fact, i left them a negative feedback.
and on top of that, their return department is extremely nasty about returns, they refused mine because I was a few days over their stingy 7 day return period......
They've long been in the garbage, so I'd suggest you go with some other sellers.
xcgames
Postby neo6205 » Fri Feb 09, 2007 3:34 am
I purchased these headlights/side markers after having a small fender bender and needed to replace one of the headlights. They are horrible. You only get like 20 ft on low beams. Not positive if it's because the bulbs they ship with are horrible or if its the black trim ring.
On a slightly different note, since I replaced the bumper, passenger fender, and both headlights/side markers 2 days ago, my running lights dont turn on. I just got pulled over driving home for not having rear running lights. The turn signals in both front and back work but no running lights. Also, when I lock or unlock the car using the fob, none of the lights blink. WTF? Any ideas?
neo6205
Postby RichD978 » Fri Feb 09, 2007 6:00 am
If you want black housing headlights with the best quality I can do a custom job using your OEM headlights. here some pictures of mines
RichD978
Postby Patrik » Fri Feb 09, 2007 6:48 am
RichD978 wrote:If you want black housing headlights with the best quality I can do a custom job using your OEM headlights. here some pictures of mines..
and for how much would you be doing this my friend :D
Patrik
Postby kwyse » Fri Feb 09, 2007 12:13 pm
those look real good. hows the light output??
kwyse
Postby SolaraBlue » Fri Feb 09, 2007 12:16 pm
^^^ they look good. they fit pretty good (not as well as stock)
light output isnt very good at all.
if you had HID's you might have better light output but with normal bulbs output isnt great....
Postby neo6205 » Fri Feb 09, 2007 7:28 pm
DO NOT BUY THESE AFTERMARKET HEADLIGHTS!!!!!
Im talking the ones on ebay.
The ones I bought gave me quite the headache. I realized they were burning out the running light fuse (behind the coin tray thingy). After dicking around for 2 hours with an ohmmeter and my dad(who is an electrician) we figured out that the harness that connects the turn signal bulbs with the existing car plug creates a short. I had to dig out my old OEM turn signal connectors to get them to stay on. That ebay seller will be getting one negative review!!
Buyer beware!
neo6205
Users browsing this forum: Google [Bot] and 74 guests
