SolaraGuy.com • View topic - Just installed + DYNOTUNED
Postby richt1271 » Thu Mar 27, 2003 8:34 pm
2001 solara v6 manual.
5.5 psi pulley + Apexi safc II JDM version, injen intake, greddy exhaust
1st run = 231.9 hp
2nd run= 237.1 hp
3rd run = 241.4 hp
Final run: 242.9 hp at wheels
232.1 torq at wheels
not bad i guess...ive seen some of you running at 250 hp at wheels. 242 isnt bad. ride feels lot smoother acceleration eheh im so happy 8) :P :D :lol:
this was done at Dynospot Racing at downtown san jose those of you live in Nor Cal. $185/dyno tune.
richt1271
Postby krook » Thu Mar 27, 2003 8:42 pm
wow! great going! manual or auto? i forgot....
btw, did you install the safc II yourself?
krook
Postby richt1271 » Thu Mar 27, 2003 8:47 pm
its manual tranny.
the shop didn't know how to install the SAFC II at first because they did a solara yesterday with the same afc they had to turn it down because they got stuck with the ECU im not sure. i had to bring them the diagram you sent me the other day, another print out on Happy Aggies site, and also bring in a japanese friend inorder to get it done. its works nicely =)
richt1271
Postby Ragtop George » Thu Mar 27, 2003 10:19 pm
Am I correct in assuming that there was S-AFC tuning happening between the runs, which is why the power increased with each run?
George
2002 Solara Convertible Automatic
TRD Supercharger, 6 PSI pulley
Apexi WS exhaust, custom Y pipe
TRD RSB on "track" setting
Ragtop George
Postby happy_aggies » Thu Mar 27, 2003 11:20 pm
PS: It's not my site.
happy_aggies
Postby lightear » Fri Mar 28, 2003 12:07 am
Ragtop George wrote:Am I correct in assuming that there was S-AFC tuning happening between the runs, which is why the power increased with each run?
Well, just keep TUNING and maybe you'll hit the 250..hahaha
lightear
Postby Flipside909 » Fri Mar 28, 2003 12:32 am
George
Yes, that's what a dynotune is. You adjust settings between each run to maximize the power.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby cdssolara » Fri Mar 28, 2003 1:47 am
I've been wondering about where to go for a dynotune here in N. Cal. When I had my S-AFC installed with a dynotune, I had it done in S. Cal. If Cattman ever finishes development of the Y Pipe and CAI, I will need another one done!
By the way, your numbers are fairly close to mine. I have a similar set-up to what you have: 5.5 psi pulley, S-AFC, RMM intake, Apexi WS catback exhaust. I ended up with 247 hp and 236 torque, both to the wheels. I plan to do enough mods to get the flywheel hp to exceed 300, which I think is a good goal for this platform, so I probably need another 10 whp.
cdssolara
Postby kondo » Fri Mar 28, 2003 12:38 pm
Motorsport dynamics in sacramento does dyno tuning for $100/hr. $65 for max hp testing.
http://www.motdyn.com/
Your numbers are pretty good. I only dynoed 186hp and 204ft lb on a auto with a stock pulley and greddy evo and injen intake. I just put on a 5.5 pulley and I am getting a SAFC installed and dynoed on 4/23. I will be happy if I can break 220. If you want to book dyno time you should call now they are booked for over a month.
Nick
kondo
SolaraGuy StickerGuy
Postby Yanks0114 » Fri Mar 28, 2003 12:44 pm
very nice numbers. Good job man
Postby richt1271 » Fri Mar 28, 2003 3:48 pm
only 186hp at wheel with stock sc/ injen intake/ and greddy?
correct me if im wrong, stock solara is around 158ish whp :o
hmm you must be running pretty lean...when i took mine in they told me i was running very lean. this was when i had stock s/c, injen, greddy.
installing the 5.5 pulley gave me a jump from somewhere around 200 to 231 hp at wheel. and the afc II tuning gave me finaly run of 242.9
i don't think u should lose that much whp from automatic tranny.
richt1271
Postby Yanks0114 » Fri Mar 28, 2003 5:01 pm
You are right, those numbers are low. He just got a S-afc :D so hopefully he can richen up the fuel mixture and gain some more power
Postby 808Camry » Fri Mar 28, 2003 6:18 pm
Dang I hope the AFC can put more power into there, man I'm gonna get real discouraged if it doesn't. That's a big power difference!
808Camry
Postby ICrazyChrisI » Fri Mar 28, 2003 8:04 pm
My SLEV6 equipped with only the Greddy got 155hp/175tq. And while they were testing the a/f mixture, they told me i was very very rich? :roll:
ICrazyChrisI
Users browsing this forum: Google [Bot] and 50 guests
