SolaraGuy.com • View topic - TRD struts tightness
Postby ReaDY-SeT-Go » Sun Feb 11, 2007 10:49 pm
hey guys i just installed some TRD struts with the springs before i just had the springs on stock struts and that lowered my car less than 1 inch in the back and 1 inch the front but the struts were hella weak so it was really bouncy... but now with the TRD struts in place... looks like i gained 2 inches in the back and 3 inches in the front like its close to stock look again so im like WTF?! :o and the tightness is seriously a really tight drive like its giving me motion sickness.... any good advice to fix this up?? im planning on letting everything settle till the end of this week... i liked my car being slammed low... so if everything doesnt settle to great i might just swap it back to stock struts... and sway all over the place :drinking: any ideas on how i can fix these TRD strut tightness and drop height??
ReaDY-SeT-Go
Postby ---CAMRAZY--- » Sun Feb 11, 2007 11:14 pm
Wait for them to settle..... And if you hate the stiffness, try COs...... LOL
Postby Sp33d » Sun Feb 11, 2007 11:22 pm
if you dont like the stiffness. give me your front struts and ill switch out with tokico's with you. its a softer ride
Sp33d
Postby ReaDY-SeT-Go » Sun Feb 11, 2007 11:33 pm
hahaha yeah i heard about those tokios... how was the drop in them?? did they raise your car or anything? cause these TRDs gave me a 3 inch lift in the front
ReaDY-SeT-Go
Postby Sp33d » Sun Feb 11, 2007 11:39 pm
well i have TRD rears with Tokico fronts. i used to like the ride, but now i find it soft.
when i had TRD's all around, i thought it was stiff as well. but now comparing it to TRD rear and tokico front, TRD all around was great.
-mark
Sp33d
Postby unbalancedwood » Mon Feb 12, 2007 7:33 am
did you cut your bumpstops?
unbalancedwood
Postby Sp33d » Mon Feb 12, 2007 1:47 pm
yeah, about half.
-mark
Sp33d
Postby ReaDY-SeT-Go » Tue Feb 13, 2007 11:17 pm
hey guys is there anythign i need to know about alignments?? cause right now my steering wheel is vibrating like crazy whenever i hit 60 haha i switched back my stock struts in the front with TRD's in the rear but i feel like i might just switch everythign back stock haha :roll: crazy huh... but when should i get the alignment>? after the shocks settle in or after a week later? i also feel like im not getting the same acceleration after i swaped the struts its like its lagging more... :-? ?
ReaDY-SeT-Go
Postby ReaDY-SeT-Go » Wed Feb 14, 2007 8:06 pm
bump for alignment question :D
ReaDY-SeT-Go
Postby unbalancedwood » Wed Feb 14, 2007 8:16 pm
Well I got mine aligned a 3 days after I installed my suspension. I'll go back sometime in a few days to get it redone. I got it done at Merchants Tire (already looked, and their not in CA) but I bought a 3 year, unlimited mile alignment so i can take it back every month...every week if I want to, it was $130. I would look for a place like that in your area. My stering wheel did vibrate at 70 a few months back, ended up being my rotors. It could also be your tires need balancing...?
Where in SD do you live? I was born on Coronado, miss the area :(
unbalancedwood
Postby ReaDY-SeT-Go » Thu Feb 15, 2007 8:20 am
i live around the fashion/mission valley area with me and funboy live close to each other haha at least you had a beach right next to you :drinking: i wish i lived somewhere cold i hate when it gets too hot down here haha did you go to coronado high school?
ReaDY-SeT-Go
Postby unbalancedwood » Thu Feb 15, 2007 8:39 am
Yeah, my dad's military, I was born there, and then revisited for about a year. Went to Coronado HS for...hummm...7th grade, the year pokemon was the craze :) lol
But with your question, try swapping back to 'TRD' and letting them settle in, which ive heard is about a week. If it wasent shaking at high speed when you had it stock I would try to get it aligned, maybe find one of those unlimited alignments for a year or two. Which is usually cheaper then bringing it in a few times anyways.
PS, I dont know that much about stuff, i just read about it and do it.
unbalancedwood
Users browsing this forum: Majestic-12 [Bot] and 49 guests
