SolaraGuy.com • View topic - rotor and pad combo....
Postby sahuddleston » Thu Feb 22, 2007 8:51 pm
i ordered brembo sport rotors..... i know the brembo pads seem to squeek really bad, anyone have some advice on a good pad for this rotor?
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby bassthrive » Thu Feb 22, 2007 9:46 pm
Every aftermarket pad I have tried has squeaked. With/without shims, even with grease, anti-sieze and anti-squeal (red or blue rubbery vibration dampening compound).
Going back to Toyota OEM ceramics. Thats my two cents.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby ClassySolaraGuy » Thu Feb 22, 2007 9:52 pm
OEM
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby anttarz » Thu Feb 22, 2007 9:54 pm
OEM ... w/ brembo rotors - no squeek
anttarz
Postby Texas Tornado » Thu Feb 22, 2007 10:12 pm
dealer pads, i think they're called akebono or something like that, no squeaks at all using them with Brembo
2003 Solara SLE 3.0 V6 - Red
Very clean adding mods.
Mods: TRD Body Kit, Injen CAI, Optima Red Top, TRD RSB, TRD FSB, TRD Oil Cap.
Texas Tornado
Postby sahuddleston » Thu Feb 22, 2007 10:28 pm
ok great. thanks guys. how much are the oem pads?
sahuddleston
Postby ClassySolaraGuy » Thu Feb 22, 2007 10:43 pm
I don't know how these are but they are TRD.
They don't make TRD pads for the Gen 2 but I got my front & rear OEM pads from a friend in the parts department for 65.00.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby sahuddleston » Thu Feb 22, 2007 11:35 pm
anyone use these???
sahuddleston
Postby Sp33d » Thu Feb 22, 2007 11:56 pm
i heard the TRD ones fade VERY quick. and they produce massive brake dust.
-mark
Sp33d
Postby sahuddleston » Fri Feb 23, 2007 12:00 am
good to know, ill just get stock ones.....
sahuddleston
Postby woa_its_j3ff » Fri Feb 23, 2007 7:21 am
you could try Hawk, I have those and they're pretty good. no noise or anything of the sort..
Postby Ian » Fri Feb 23, 2007 9:27 am
Akebono brake pads + brembo cross drilled rotors. No squeak, no dust, excellent stoppage. I've had that combination for 2 years without a problem.
Oh, don't forget to get Goodridge steel braided brake lines. This makes the most difference, in feel at least.
Ian
Postby krook » Fri Feb 23, 2007 12:34 pm
woa_its_j3ff wrote:you could try Hawk, I have those and they're pretty good. no noise or anything of the sort..
they're MAD dusty though....
i got the same--Hawk HPS front, but OEM pads in the rear. the difference between the front and rear wheels is clear.
krook
Postby campfire9 » Fri Feb 23, 2007 2:35 pm
I have Brembo cross drilled and slotted rotors for about 4 years now with no trouble at all. I now have Raybestos ceramic pads that are absolutely great. No dust and the shims are layered so there is no vibration or noise. The system really works.
campfire9
Postby SleeperSolara » Mon Feb 26, 2007 7:45 am
I have Brembo cross-drlled rotors and AutoZone ceramic pads.....
Yeah my rotors are already warped. :x
So i think i'm goin' to get ATE slotted rotors next.
Been tryin' to fix my brakes, cause they don't catch that fast.
Users browsing this forum: Majestic-12 [Bot] and 49 guests
