SolaraGuy.com • View topic - Quiet Muffler
Quiet Muffler
Quiet Muffler
Postby PiterNYC » Thu Mar 01, 2007 10:40 pm
Im thinking to get a aftermarket muffler for my solara, but I dont want one that is loud. Does any of you know which muffler will give me nice look and it wouldnt be much louder than stock ?
Thanks.
PiterNYC
Postby ClassySolaraGuy » Thu Mar 01, 2007 10:44 pm
Are you looking for some performance gains or just looks?
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby PiterNYC » Thu Mar 01, 2007 10:45 pm
Just the look, but if I could have both at the same time its even better.
PiterNYC
Postby ClassySolaraGuy » Thu Mar 01, 2007 11:05 pm
I know the TRD muffler isn't that loud at all plus it looks nice. It is however on the pricey side though. You could get a custom cat back exhaust job done at a muffler shop for less than what you would pay for a TRD muffler by itself. I would look at the following:
-Stock muffler with new tip (Looks, no sound change & no performance gains)
-Universal muffler or after market (Looks, sounds & better exhaust flow with some performance gains.) If you decide to upgrade your piping I wouldn't go larger than .25in from the stock size unless you plan on getting a supercharger for it. Too big of a pipe will decrease back pressure & result in loss of torque.
- TRD muffler that's a straight up bolt on & can be installed yourself in less than a hour tops. (Looks, Mild sound change & performance gains are debatable)
Keep in mind that if you do go after market or TRD that you have your resonator kept in place to filter out sound as well.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby DatSRBoi » Thu Mar 01, 2007 11:07 pm
WS Apexi is nice.
Postby PiterNYC » Thu Mar 01, 2007 11:34 pm
ClassySolaraGuy wrote:I know the TRD muffler isn't that loud at all plus it looks nice. It is however on the pricey side though. You could get a custom cat back exhaust job done at a muffler shop for less than what you would pay for a TRD muffler by itself. I would look at the following:
Thanks, and do you think if I will go with a Magnaflow street series muffler it should be quiet ??
Heres a picture of the muffler
http://performancepeddler.com/images/14829.jpg
PiterNYC
Postby PiterNYC » Thu Mar 01, 2007 11:36 pm
WS Apexi is nice but expensive :( , I just want muffler that looks nice, and its quiet
PiterNYC
Postby ClassySolaraGuy » Thu Mar 01, 2007 11:44 pm
PiterNYC wrote:Thanks, and do you think if I will go with a Magnaflow street series muffler it should be quiet ??
No problem...When you do get your exhaust let it break in for about 500 miles or so to see if you like the way it sounds or not. You could always upgrade your resonator to filter more sound if its to much for your liking.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby PXLpainter » Thu Mar 01, 2007 11:49 pm
If you just want cosmetic, then stick with your OEM muffler and put a tip on it. ;)
Postby DaTwUnKrAziEpInOy » Fri Mar 02, 2007 1:04 am
i'd like to add also that V6s do have a quieter exhaust note compared to a 4cyl. Just food for thought if you're going the custom route.
DaTwUnKrAziEpInOy
Postby jhenty » Fri Mar 02, 2007 6:19 pm
magnaflows are going to be too loud. Just get the Apexi WS, i have one which i purchased after spending money on another muffler that was too loud so then spent more overall. Buy quality from the start, you wont regret it. If you don't have the money to mod, dont do it.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby Midias » Fri Mar 02, 2007 8:54 pm
PiterNYC wrote:WS Apexi is nice but expensive :( , I just want muffler that looks nice, and its quiet
Go custom on a Dynomax super turbo it will be perfect for you they make a great sound not to loud and you can add a custom tip. like this one
http://www.youtube.com/watch?v=83H_84izTJg
Here is my trd with a few extras
Here are some vids of my Solara
In case you are curious I have
CPE intake with ECU upgrade
TRD exhaust 2.5 inch piping custom resonator
custom Y pipe
Magnaflow high flow cat
Light weight URD pulley
Plasma booster
Hyper Voltage
TB Spacer
Ground wire upgrade
NGK iridium Plugs
NKG wires
Thats about it.
FLY BY
http://s86.photobucket.com/albums/k93/m ... 0_0094.flv
Next solara vid
http://s86.photobucket.com/albums/k93/m ... 0_0095.flv
SWEET
Last one not quite redlineing it
http://s86.photobucket.com/albums/k93/m ... 0_0092.flv
had to watch for snow drifts
Postby PiterNYC » Fri Mar 02, 2007 10:42 pm
Thanks Guys , I was looking at Apexi WS II today it looks cool and if you say that its quiet I will think about it. Thanks again
PiterNYC
Postby PhreakdOut » Fri Mar 02, 2007 11:27 pm
Honestly, if appearance is all you want, I agree. Stick with the OE muffler and a tip. Treat it to a fresh coat of high temp black because I'm sure the OE paint has flaked off by now. (ArvinSango Inc makes the OE muffler and their paint process is inferior.)
If you MUST change the muffler, go with the largest body you can fit in there. You will need a offset inlet / center outlet muffler. (Dynomax Superturbos are reverseable as so are MagnaFlows.)
SuperTurbo 17730 has 2" inlet and outlet tubes. The Muffler can size these up slightly to be a closer match to your OE pipe size.
Otherwise the SuperTurbo 17731 has 2.25" inlet and outlet. New inlet elbow and out spout would need to be made anyway. 2.25" will be slightly louder than the 2". Again, it depends on what you want. The OE system has restrictions after the inlet pipes down to 48.6mm (1.91").
Postby jhenty » Sat Mar 03, 2007 6:45 am
you dont have to buy the whole exhaust system to get the Apexi WS, they sell just the muffler for $200.
1990 BMW 535i
jhenty
Users browsing this forum: Google [Bot] and 72 guests
