SolaraGuy.com • View topic - WILL THIS FIT ????
WILL THIS FIT ????
WILL THIS FIT ????
Postby netherland24 » Mon Mar 05, 2007 8:28 pm
5X100/114.3
73.1
42mm
18inch
for rims
someone locally is selling Tenzo R RS 5 rims for 400$ with tires... black with chrome lip.....
http://www.tenzoracingsports.com/roadwh ... pup01.html
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby woa_its_j3ff » Mon Mar 05, 2007 8:29 pm
yeah it should fit man. those rims look pretty decent.
Postby netherland24 » Mon Mar 05, 2007 8:31 pm
can anyone photoshop them on the GEN 1 lowered?
00 SS Lara 277hp
netherland24
Postby QuickSEV6 » Mon Mar 05, 2007 8:43 pm
I can't verify if they fit or not, but they look nice.
Postby RichD978 » Mon Mar 05, 2007 8:51 pm
woa_its_j3ff wrote:yeah it should fit man. those rims look pretty decent.
how would you even know if they fit or not? just cause the bolt pattern is right..
well anyways, the offset makes a big difference on whether or not they will fit good or not and/or if they'll rub also what size are the tires
RichD978
Postby netherland24 » Mon Mar 05, 2007 9:14 pm
from what i can see from the pictures... it says
35/R18/ 84w?
Not sure if it is 235... i asked just waiting for response....
00 SS Lara 277hp
netherland24
Postby netherland24 » Mon Mar 05, 2007 9:39 pm
anymore info
00 SS Lara 277hp
netherland24
Postby ThatVietGuy » Mon Mar 05, 2007 9:57 pm
I assume the offset is +43, so I think it should fit.
ThatVietGuy
Postby SpikedMantis » Tue Mar 06, 2007 12:53 pm
The wheels might rattle with the bore being larger. I think stock is 60.1mm
This is the space where I should write something witty or clever, hoping to show some personality.
SpikedMantis
Postby Sebas007 » Tue Mar 06, 2007 1:03 pm
guys !!
width and offset are in a tight relationship...they cannot be dissociated.
What is the width of the wheel ??
73.1 mm ??????? (Impossible)
You just miss the width data since you know all the rest.
what is the tire size ???
235/35R18 ??????
And what is stock width/offset of Gen 1 ??
Postby SpikedMantis » Tue Mar 06, 2007 1:10 pm
Sebas007 wrote:guys !!
73.1mm is the center bore. Stock 16s are 16x6 I believe with a 45mm offset.
SpikedMantis
Postby ---CAMRAZY--- » Tue Mar 06, 2007 2:51 pm
For the Center Bore all you need are Hub centric rings, a big factor that is not in the question is the width of the wheel. Also if the offset doesnt work out, try some spacers 10 or 15 mm's are fine... Go with H&R since they are hub centric and come with longer studs to replace.
To answer your question, YES, they will work, what width are you going with?
Postby netherland24 » Tue Mar 06, 2007 2:53 pm
http://i16.tinypic.com/2s9akud.jpg
here is a pic of the side of the tire...
00 SS Lara 277hp
netherland24
Postby indiglosolara » Tue Mar 06, 2007 2:59 pm
Tenzo only made that wheel in 18x7.5 with a 5x114.3/100 with a +42 offset.
You will need hub centric rims from a 60.1mm to a 73mm. With 18x7.5 +42 offset they will fit with 225/40/18 tires, But with 235/35/18 you will run smaller then stock and speedo will be off. Also smaller side wall will result in wheel being more prone to damage from potholes.
indiglosolara
Solara 2 xB
Solara 2 xB
Postby Sebas007 » Tue Mar 06, 2007 3:11 pm
Voila
Anyhow the tire will not last that long...so you'll be able to pick better size for your car...but not the end of the world.
What is the stock tire size for Gen 1...I'm not enough familiar with it
Users browsing this forum: Majestic-12 [Bot] and 49 guests
