SolaraGuy.com • View topic - Can anyone help?
Can anyone help?
Can anyone help?
Postby richt1271 » Thu Apr 03, 2003 12:30 am
trying to find a installation manual for 2001 solara trd quickshifter... anyone knows a site or has a layout of what tools i will be needing and the procedures?. thanks!
richt1271
Re: Can anyone help?
Postby Flipside909 » Thu Apr 03, 2003 8:55 am
richt1271 wrote:trying to find a installation manual for 2001 solara trd quickshifter... anyone knows a site or has a layout of what tools i will be needing and the procedures?. thanks!
The installation is straight forward. You will need needle nose pliers for the most part. Luc has a step by step install of this but a conversion on his Gen3 SE V6. Unscrew the old shifter knob...and pull up on the shifter bezel (it's held by 4 clips). The hardest part is to remove the speed (locking clip) holding in the pin that holds part of the assembly over the shifter ball down...and actually pulling out that pin without bending or distorting it. Everything else is straight forward.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
