SolaraGuy.com • View topic - RSB squeaking Lke CRAZY!
Postby Sap Z » Wed Mar 21, 2007 7:21 am
Hello there,
So when i first installed my RSB i lubed the ushings well and also wrapped that area with tape.
Few month after it started sqeaking here and there. So i went and got it lubed since i didnt fele like getting under and doing it myself.
Now after 3-4 months AGAIN its squeaking...well more than a squeak..more like a creaking noise. N its fuking annoying...every bump..every turn...ARGH
WHAT DO I DO? I'm This close to putting my stock back one :(
elp!
SapZ
V6 SE DWP
Sap Z
Postby hskrsolara » Wed Mar 21, 2007 7:31 am
Maybe you need new bushings? Or how about just loosening the brackets and applying more lube to the bushings? pretty easy fix.
hskrsolara
Postby jhenty » Wed Mar 21, 2007 5:12 pm
I have the same problem, its because its cold out and urethane doesn't like that, it makes it harder and thats where the squeaking comes from. Try using the gel on them again or just wait for warmer days like me.
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby DaTwUnKrAziEpInOy » Wed Mar 21, 2007 5:16 pm
TRy a silicone/teflon base lube. It has a wide operating temperature and won't wash off easily. You can find something like that in pool/jacuzzi service shops.
DaTwUnKrAziEpInOy
Postby kingkakyle » Wed Mar 21, 2007 5:16 pm
someone i think on gen 2 forums said use the mobile 1 synthetic grease they sell
its meant for below freezing temps, so it wont squeak
Postby ClassySolaraGuy » Wed Mar 21, 2007 5:27 pm
kingkakyle wrote:someone i think on gen 2 forums said use the mobile 1 synthetic grease they sell
I also used this to lube the new RSB on the Gen 2. Its very resistant to water or anything for that matter. Its about 4-6 dollars to get.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby lilm » Wed Mar 21, 2007 6:52 pm
^^thats what i used
lilm
Postby trdkamuri51o » Wed Mar 21, 2007 7:00 pm
yep same here no problems ever..
trdkamuri51o
Postby CamryOnBronze » Wed Mar 21, 2007 7:44 pm
I have heard marine grease works well as well because it is extremely water resistant and has a large temp range... good luck!
Postby Sap Z » Thu Mar 22, 2007 6:37 am
where do i get marine grease from?
SapZ
V6 SE DWP
Sap Z
Postby CamryOnBronze » Thu Mar 22, 2007 6:51 am
To be honest Im not exactly sure, it may be described as "marine grade," I tried searching quickly on toyota nation but wasnt able to find a specific name. Sorry I cant help more.
Postby Midias » Thu Mar 22, 2007 7:58 am
Search around I have seen bushings with a grease fitting I might go with those that way a few quick squirts with a grease gun and all set.
