SolaraGuy.com • View topic - brembo squeeking in the AM hours
Postby Jai_Jai_Binks » Wed Mar 28, 2007 2:37 pm
I have brembo blanks in the front (changed in May 2006 w/ OEM pads - so i'm guessing close to 5K miles on them) AND
brembo blanks in the rear (changed october 2006 w/ OEM pads) and the rears have close to 3K miles on them.
Whenever we reverse our car out of the driveway in the AM hours the brakes squeek. This is the only time they squeek. The car drives great, the breaks feel great, and pad looks new, the brake fluid is all clear (was flushed out in May 2006 - hence its new fluid there too). 99.999% i know its all good, but is there anything else i should look into to get that annoying AM squeek gone. LMK what you guys/gals think??
Postby scLara626 » Wed Mar 28, 2007 2:42 pm
Most likey rust devolops over night on the rotors and once you press the brakes, the pad cleans off the rotor. i guess.........
" I heard (YOUR NAME GOES HERE) got fired from the sperm bank for drinking on the job''
scLara626
Postby Jai_Jai_Binks » Wed Mar 28, 2007 4:01 pm
Initially i guessed it was surface rust that was causing the squeek. But i don't see anything..and besides aren't brembo's anti-rust?
We do park inside (closed garage) and no access to moisture or due or sprinklers.
