SolaraGuy.com • View topic - HID QUESTION
HID QUESTION
HID QUESTION
Postby Sikh1MZFE » Thu Apr 19, 2007 4:03 pm
Hi guys i just got my hid kit in today it the mcchulloh kit 8000k. I know its plug and play but can anyone show me a thread where its shows pics etcc on how the ballast were mounted and where they where. and if they just used two sided tape or screws and two sided tape. I just want to know what are the best locations to mount the ballast and just a step by step on how to install the hid kit. I looked on the forum but coulndt find a thread like that.
thank you
Sikh1MZFE
Postby ThatVietGuy » Thu Apr 19, 2007 5:03 pm
Put one under the battery and the other behind the washer filler tube.
ThatVietGuy
Postby Sikh1MZFE » Thu Apr 19, 2007 7:05 pm
ThatVietGuy wrote:Put one under the battery and the other behind the washer filler tube.
Thanks bro, do you think that double sided tape byitself is good enought or should i use screws as well??
Sikh1MZFE
Postby Sikh1MZFE » Thu Apr 19, 2007 7:06 pm
Any more info on installing help and or tips are welcome!!!1
Sikh1MZFE
Postby sahuddleston » Thu Apr 19, 2007 8:00 pm
go buy 3m double sided tape. i used that and its been great. other than that, put the ballasts under the battery, and depending on if you have an se or sle you can put it in front of or behind the washer filler tube. also, be sure to zip tie and secure the harness and wires.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby Sikh1MZFE » Thu Apr 19, 2007 8:05 pm
sahuddleston wrote:go buy 3m double sided tape. i used that and its been great. other than that, put the ballasts under the battery, and depending on if you have an se or sle you can put it in front of or behind the washer filler tube. also, be sure to zip tie and secure the harness and wires.
Great Thanks!!!!
Sikh1MZFE
Postby Midias » Thu Apr 19, 2007 8:12 pm
get the 3m outdoor/indoor tape I got some at home depot 3 in holds 1 lb
Postby SolaraGuy22 » Thu Apr 19, 2007 8:33 pm
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Sikh1MZFE » Thu Apr 19, 2007 8:56 pm
SolaraGuy22 wrote:Check this out Sikh1MZFE http://www.solaraguy.org/viewtopic.php?t=30298
Thanks BRO, that was a nice thread, mounting the ballast under the headlights by removing the headlights first is a good spot.
Sikh1MZFE
Postby krawzyazn » Thu Apr 19, 2007 9:04 pm
Should have came with double sided tape!
Postby Sikh1MZFE » Thu Apr 19, 2007 10:19 pm
Yea in the item description it sayed the tape was included, but none came in the box, so i emailed them and lets see if they send the tape, that way i dont have to go out and buy some.
Sikh1MZFE
Postby woa_its_j3ff » Fri Apr 20, 2007 8:15 am
I have mine behind the battery where the strut bar is and passenger side is right next to the windshield washer fluid.
Postby krawzyazn » Fri Apr 20, 2007 8:34 am
you bought it on ebay?
your supposed to get zip ties and double sided tape also instructions
Postby tito53 » Fri Apr 20, 2007 10:10 am
just make sure to secure it with that tape and zip ties and that it doesnt touch the metal of the body!
tito53
Postby Sikh1MZFE » Fri Apr 20, 2007 11:10 pm
krawzyazn wrote:you bought it on ebay?
Yea i got everytihng but the tape!!! i pmed you first about the hid's but you never replied!!! i would have rather bought them from u, but oh well , when i do my fogs i will go through you.
Sikh1MZFE
