SolaraGuy.com • View topic - HEADLIGHT CONVERSION Gen 1 - Gen 1.5
Postby SpeedySolara » Mon Apr 23, 2007 4:11 pm
OK I have a little issue. I have a 99 Solara with H4 headlight bulbs. Now that I have the 2003 bumper and headlights theres a problem, the gen 1.5 has 9005 & 9006 headlight bulbs. Converting the body is no problem, how do I convert the wiring so that it could be funcional with the 2003 headlights. I would appreciate anyones help. Thanks.
SpeedySolara
Postby lilm » Mon Apr 23, 2007 4:28 pm
you can prolly just pul the harness off in a junkyard
lilm
Postby krawzyazn » Mon Apr 23, 2007 4:34 pm
they make a harness that converts the H4 to 9006/9005 or you can make your own
Postby Astro » Tue Apr 24, 2007 8:17 am
Just solder the wires together, low to low, high to high, and ground to ground. It's pretty easy. Check out this conversion done on a Corolla, it's the same for us.
http://vamp.darkravers.net/cpg/displayimage.php?album=7&pos=6
Postby NeFaRiOuS_SLE » Tue Apr 24, 2007 3:43 pm
Well at one point I was interested in redesigning the Gen1.0 headlight bracket to have a projector low and a reflector high (kinda like the Gen2 design) and getting HIDs... Not to thread jack but out of curiosity, is there a way to have the low beams stay on when you flash your highs? I don't want to kill the HID by flashing the numerous amount of Fresh-Off-The-Boat idiots around here!
Postby Astro » Wed Apr 25, 2007 8:54 am
^^^^I'd like to find out the same........
Postby xavier » Thu Apr 26, 2007 12:49 pm
I believe its illegal to have the low beams on with the high beams but I am planning something similar anyway :)
xavier
