SolaraGuy.com • View topic - Solara 2002 TRD springs and KYB struts HELP
Postby jbittner1002 » Tue Apr 24, 2007 8:28 pm
Just had new TRD springs and KYB struts installed in my car. Now the rear wheels no longer fit, they rub on the top strut spring lip. Both the current Enkei Racing Series RP03 17X7 215/50/17 and the old stock 205/60/16 rub. Did my installer do something wrong ? Are KYB not a correct fit ? My installer now wants me to go out and replace the tires with 215/45/17 to fix this. I noticed on this site that some people have 18 on there car so I would think the 17s should fit Any ideas? Any help is appreciated.
Thanks
John B
jbittner1002
Postby Mole » Tue Apr 24, 2007 8:45 pm
please read the forum descriptions and post in the correct forums.
Postby Astro » Wed Apr 25, 2007 8:52 am
What is the offset of the rim? It must be between +38 to +42. If you know what you're doing, you could go as low as +35 and as high as +50. I'm betting your rims are less than +35.....
Postby krawzyazn » Wed Apr 25, 2007 9:10 am
Astro wrote:What is the offset of the rim? It must be between +38 to +42. If you know what you're doing, you could go as low as +35 and as high as +50. I'm betting your rims are less than +35.....
if its rubbing on the strut your rim offset is over 45 if it rubs the fender then your offset is lower then 35
I have the same set up and had 19X8 40 offset with out any problems
Postby Astro » Wed Apr 25, 2007 9:40 am
Thank you, Mark. I've got +35 and my rim is mm's away from my spring. You might be able to put a penny inbetween. :o I guess that's what a 8.5" rim and 235 tire will do.....
Postby Toy1mzfe » Wed Apr 25, 2007 12:42 pm
iono.. he said his stockers rub too. so that might mean somthing else is f-ed up on his suspension.
Postby jbittner1002 » Wed Apr 25, 2007 4:14 pm
Last night I started to research this issue. I came to the conclusion that there had to be something wrong with the install or the struts themselves.
A ton of others have the same setup with bigger rims and they fit..so why?
So I went onto KYB web site and looked up the part numbers to match up.
I turns out the auto parts dealer sold me Camry struts... not solara. This is why the tires didnt fit. It seems some of the parts lookup systems cross ref the camry KYB part number to the solara. Today I got the right part and the wheels fit now. The installer didnt notice that the struts were different so now I have to pay extra labor. At least the auto parts dealer accepted the return of the camry struts. Live an learn ...
Hopefully this listing will help someone else avoid this in the future.
John B
jbittner1002
Postby krawzyazn » Wed Apr 25, 2007 4:21 pm
hmm camry struts 97-01 fit the solara 99-03
92-96 camry might fit the solara also
Postby jbittner1002 » Wed Apr 25, 2007 4:35 pm
The camry KYB strut did fit but the bottom spring plate on the rear is lower then solara KYB struts , this is why the tire rubed.
jbittner1002
Postby CamryOnBronze » Wed Apr 25, 2007 6:21 pm
I believe the fronts from a 92-96 camry fit but not the rear... or maybe its the other way around, but I dont think all of it fits.
