SolaraGuy.com • View topic - Fron Turn Signal HELP!!!!
Postby Sikh1MZFE » Thu Apr 26, 2007 1:08 pm
I purchased this http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=009&sspagename=STRK%3AMEWN%3AIT&viewitem=&item=190105832313&rd=1, and when i installed it my right friont signal started blinking faster then my left, my left stil lhas regular stock bulb in it. Well Its blinking like 3x the speed it should be blinking. WHY IS THAT??? did i blow a fuse, but if thats the case why is th bulb still blinking, im confused, please help!!!!!
thanks
Sikh1MZFE
Postby Midias » Thu Apr 26, 2007 6:54 pm
I swear these kids today don't even know the difference between a LED and a tungsten filament bulb. The LED bulb had remarkably less resistance and therefore is causing your relay which is probably electric and relays on a capacitive circuit to work is now charging and discharging faster. You need to add some series resistance, or just ditch the damn led signals and use a regular bulb.
Postby Ruski » Thu Apr 26, 2007 7:34 pm
or get blinker fluid.. it might need a flush
Postby lilm » Thu Apr 26, 2007 8:24 pm
HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHHA
in non car guy terms..........the little lightbulb you bought(led) uses a whole lot less elcktrickty(electricity) than the normal bulb(filament) causing the light to blink faster.....just change both lights to led's and you will be fine
lilm
Postby woa_its_j3ff » Thu Apr 26, 2007 9:15 pm
Ruskimafia wrote:or get blinker fluid.. it might need a flush
synthetic blinker fluid i would assume. that goes directly into the flux capacitor
Postby iinokturnolii » Thu Apr 26, 2007 9:30 pm
come on guys... that blinker fluid thing... is getting killed... it was funny the first 100,000 times... but yeah.... you get the point... :roll:
Sikh1MZFE... i think "load resistors" will do the trick...
http://frickinbrite.com/catalog/product ... cts_id=113
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
Postby Ruski » Fri Apr 27, 2007 7:41 am
^^ Party Popper !!!! It wasn't used in a while so i had to bring it up
Postby iinokturnolii » Fri Apr 27, 2007 4:04 pm
Ruskimafia wrote:^^ Party Popper !!!! It wasn't used in a while so i had to bring it up
nah :P ... aint trying to party poop on yall little parade :bday: ... but Jeff is just killin it... "i think he overfill his blinker fluid joke?"
iinokturnolii
Exotic Herb Sampler
Exotic Herb Sampler
