SolaraGuy.com • View topic - Rear say bar size
Rear say bar size
Rear say bar size
Postby Midias » Sat May 12, 2007 7:55 pm
Does anybody know the size of the TRD rear sway bar I am in the process of tracking down some non squeaky bushings and I need to know. I think they are 21 mm but can anyone confirm.
Postby Mole » Sat May 12, 2007 8:49 pm
19 and 21
Postby Jon11582 » Sat May 12, 2007 8:54 pm
the bushings that come with it are fine. To get rid of the squeaking, just use lots of lube and plumber's tape and more lube, before you put on the bushing.
2000 Black Solara SE
Jon11582
Postby Midias » Sun May 13, 2007 6:02 am
Jon11582 wrote:the bushings that come with it are fine. To get rid of the squeaking, just use lots of lube and painter's tape and more lube, before you put on the bushing.
I have it well lubed
as for the tape do you mean the blue painters masking tape?
and is it 19 or 21 for the TRD or both on gen 1
Postby jhenty » Sun May 13, 2007 9:26 am
i have the same problem, its gone away with the warm weather for the most part. Side note: which hole is the track setting on the trd sway bar? the one closer or further away?
2005 Subaru legacy GT
1990 BMW 535i
jhenty
Postby CASTRO » Sun May 13, 2007 10:14 am
no, not painters tape, you have to get the teflon white plumbers tape. most commonly used for piping
CASTRO
Postby Jon11582 » Sun May 13, 2007 10:35 am
CASTRO wrote:no, not painters tape, you have to get the teflon white plumbers tape. most commonly used for piping
Thanks for the correction, I was thinking plumbers tape, but wrote painters tape.
Post updated.
Mine has never squeaked with stock bushings.
Jon11582
