SolaraGuy.com • View topic - Does this CAI install look okay?
Postby Dawgz » Sun May 27, 2007 6:25 pm
Im doubting it, but thats the only way it fits, and the damn fuse box isnt COMPLETELY screwed in either....
Postby woa_its_j3ff » Sun May 27, 2007 6:31 pm
... how would it NOT look okay? ..
Postby Dawgz » Sun May 27, 2007 6:33 pm
dude, i dont know...
Postby AznDragonV » Sun May 27, 2007 6:43 pm
thats how mine looks..my fuse box isnt screwed i at all i dont think...i had to put some tape around the screws cuz i couldnt get them out..and i couldnt screw them in..
AznDragonV
Postby PXLpainter » Sun May 27, 2007 6:44 pm
Screw the looks - how does it sound/perform now? :D
Postby Akfahad » Sun May 27, 2007 6:53 pm
that's right, i didn't even bother screwing in the extension, I actually had a shop cut it off because it was making a serious gouge in the fuse box.
Postby Dawgz » Sun May 27, 2007 7:16 pm
AznDragonV wrote:thats how mine looks..my fuse box isnt screwed i at all i dont think...i had to put some tape around the screws cuz i couldnt get them out..and i couldnt screw them in..
Do ur Radiator Fans turn on and off randomly now?
Postby Dawgz » Sun May 27, 2007 7:17 pm
PXLpainter wrote:Screw the looks - how does it sound/perform now? :D
lol, i babied it a bit, but then i let it rip, before the s\c kicks in @ 3k, at around 2.5K u can heat the intake, it ALMOST sounds like a baby S|C whine, pretty cool.
Havnt noticed anything with Speed gains tho, ill check it out later on tho.
Postby AznDragonV » Sun May 27, 2007 7:23 pm
randomly? not that i know of..but do your fans trun off while ur car is hot? cuz i think that the fans only turn on depending if they need to or not? im not quite sure...but it doesnt seem like mine turn on and off randomly.
AznDragonV
Postby Dawgz » Sun May 27, 2007 7:25 pm
Akfahad wrote:that's right, i didn't even bother screwing in the extension, I actually had a shop cut it off because it was making a serious gouge in the fuse box.
why did u have it cut off?
Postby Dawgz » Sun May 27, 2007 7:27 pm
no i heard of an issue where the fans were not Turning on correctly as they are set to.
They do turn on and off according to the temperature, but i heard that the fuse box, when u move it, something messes up the GRounding and fcks with the fans. I gotta test it out tomorrow.
Postby Akfahad » Sun May 27, 2007 7:47 pm
Dawgz wrote:
Akfahad wrote:because it was making a serious gouge in the fuse box.
Postby AznDragonV » Sun May 27, 2007 7:57 pm
o ok..you should let me know when u find out lol
AznDragonV
Postby hskrsolara » Mon May 28, 2007 8:29 am
looks good...none of the extensions fit perfect, mine looks the same as yours.
hskrsolara
Postby Astro » Mon May 28, 2007 9:07 am
Mine is pretty much the same. I did cut a bit of metal on the bottom side to get it to sit a little better.
