SolaraGuy.com • View topic - thrttle body spacer
thrttle body spacer
thrttle body spacer
Postby AznDragonV » Mon May 28, 2007 1:25 pm
i know some ppl on here have a throttle body spacer
did you guys get a noticable gain from it?
can you still use it if you have a CAI?
where did you get it and how much?
thanks
AznDragonV
Postby Midias » Mon May 28, 2007 1:45 pm
A quick SEARCH using the wonderful SEARCH function yields some old threads I even included some good quotes that I found using the SEARCH function.
Posted: Tue Jun 06, 2006 12:00 pm Post subject:
OK I got it in. The Home Depot did not have 65mm m8X 1.25 bolts just 70 and 60, so in a lapse of good judgment I got 60mm The fit on the top 2 holes no washer. I will be getting 70 mm eventually. 60 mm does NOT fit the bottom 2 holes. I used the 90 mm that came with it and 2 washers each from the kit; I will probably try 70 mm later on. Other than that install was easy.
How did it feel well it is hot out today so I cannot wait for evening to really have fun but I do feel like midrange has had a nice improvement and I would recommend it as a cheap mod for other people. Second gear feels a lot nicer and the powerband feels smoother. I will try to get pictures soon.
****** Update
On the top use m8 X 1.25 70mm long and on the bottom use 2 of the 90 mm long that came with the kit and 2 washers under each 90 and 1 under each 70mm. You will need to also buy 2 m8 washers for the top sense the kit only comes with 4.
Origional Thread
http://www.solaraguy.org/viewtopic.php? ... e41509aafb
Pictures
http://www.solaraguy.org/viewtopic.php? ... tle+spacer
Redknights report of 20% ariflow increase
http://wheelskin.com/spe-34055.html
Here I found this as the cheapest place, even cheaper than the same company's ebay stuff 79.99 free shipping and enter the coupon code HELIX and get 4 dollars off
Just ordered mine they take paypal yey
I also found a couple a little cheaper on ebay but I wanted the one Greg mentioned.
Postby AznDragonV » Mon May 28, 2007 1:47 pm
sorry..i searched fo throttle body spacer and 3 threads came up...ill search harder next time
AznDragonV
Postby Midias » Mon May 28, 2007 1:50 pm
AznDragonV wrote:sorry..i searched fo throttle body spacer and 3 threads came up...ill search harder next time
It's cool I searched for throttle and spacer together worked well.
Postby AznDragonV » Mon May 28, 2007 1:54 pm
thanks a lot of compling all this information on one page
AznDragonV
Re: thrttle body spacer
Postby Midias » Mon May 28, 2007 3:28 pm
AznDragonV wrote:i know some ppl on here have a throttle body spacer
thanks
Oh yea BTW
Yes
Yes
and about 75 bucks
Postby kwyse » Mon May 28, 2007 3:30 pm
Does the one in the link work for the solara? I didn't check the VIN # like the website says, but it is listed for 4runner and tacoma. Is this the same one u got midias or is there one for solaras?
kwyse
Postby AznDragonV » Mon May 28, 2007 3:56 pm
Greg has a 2000 and Midias, you have a 2001... and i have a 1999. so this TB spacer will fit all gen 1 correct?
AznDragonV
Postby Midias » Mon May 28, 2007 4:05 pm
kwyse wrote:Does the one in the link work for the solara? I didn't check the VIN # like the website says, but it is listed for 4runner and tacoma. Is this the same one u got midias or is there one for solaras?
There is none for the solara you need one for the tachoma. You also need some new screws read above I found them at home depot.
AznDragonV wrote:Greg has a 2000 and Midias, you have a 2001... and i have a 1999. so this TB spacer will fit all gen 1 correct?
Yes it will fit your 99
Postby AznDragonV » Mon May 28, 2007 10:13 pm
is this the exact same thing as the website you posted Midias?
http://cgi.ebay.com/ebaymotors/Tacoma-T ... enameZWDVW
AznDragonV
Postby Midias » Tue May 29, 2007 4:12 am
no you want one for the 3.4L
Postby SleeperSolara » Tue May 29, 2007 7:49 pm
I have a 2000 Solara V6, and i have a T/B spacer also.
You have a slight gain, but you have to extend some wires/cut some tubin' cover to make some room.
Postby AznDragonV » Tue May 29, 2007 8:10 pm
extend wat wire and cut wat tubing?
AznDragonV
Postby AznDragonV » Wed May 30, 2007 12:21 am
since i live in Colorado, high alittude, do you think i would get any noticable gains with this?
AznDragonV
Postby Midias » Wed May 30, 2007 4:12 am
I did not extend anything to make mine work.
Users browsing this forum: Google [Bot] and 51 guests
