SolaraGuy.com • View topic - question about tires
Postby woa_its_j3ff » Mon May 28, 2007 7:57 pm
I'm looking to get some new sets of tires for my rims.
tried tirerack, etc...
i read a lot before deciding to post up on here so..
my rims are 17in. stock everything wheel-wise, meaning i have no spacers or anything like that that i modified or changed to make my rims fit.
question is, will this size tire fit on the lara?
235/45/17 ?
any info or anything of the sort please let me know, thank you.
Postby woa_its_j3ff » Mon May 28, 2007 10:55 pm
bump.
anyone?
Postby Mole » Mon May 28, 2007 11:00 pm
stick with 225, less headache.
unless you go with a narrow footprint tire..
Postby woa_its_j3ff » Tue May 29, 2007 12:11 am
okay thanks Mole.
so 225/45/17 would fit?
Re: question about tires
Postby ---CAMRAZY--- » Tue May 29, 2007 12:19 am
woa_its_j3ff wrote:I'm looking to get some new sets of tires for my rims.
235/45/17 ?
What offset and width? That is a big role on tire sizes..... In other words, your car didn't come with 17's as stockies, so what tire size do you have there now?
Postby woa_its_j3ff » Tue May 29, 2007 12:21 am
I am running 215/45/17s.
very very THIN tires :( i made a bad choice when getting tires yes I know so this time im doing my hmwk.
these tires look low profile but they are just rubberband thin. makes a huge gap in the wheel wells as you can tell from the pics sorta.
Postby ---CAMRAZY--- » Tue May 29, 2007 12:31 am
Do you know the width of your 17s?
Postby woa_its_j3ff » Tue May 29, 2007 12:32 am
how would I find that out?
Postby funboy102 » Tue May 29, 2007 3:33 am
if you can tell us the name of your rim, we can maybe look it up. Make and model of your rim.
But 225 sounds appropriate. If you want to keep the overall diameter as your stock tire, you would need a 50 aspect ratio. (http://www.miata.net/garage/tirecalc.html)
Keeping in mind that stock was 205/60/16
Yeah it'll probably fit, but the lower aspect ratio will leave a bigger gap.
funboy102
Postby woa_its_j3ff » Tue May 29, 2007 4:23 am
funboy102 wrote:if you can tell us the name of your rim, we can maybe look it up. Make and model of your rim.
my rims are ADR Sokudo 10s
and my MAIN concern this time when getting tires is to eliminate the tire/fender gap as much as possible. my current tires are way too "thin" and already make the gap bigger than it already should be without my drop.
I dont wanna push the tire/rim too much but i wanna do it just enough, but safely.
Postby 2kSoulara » Tue May 29, 2007 7:10 am
I have 225/45/17s and i just got some Khumo Ecstas for 385 total from discounttire.com. These tires are mad quiet! grip great and look great they are excellent "budget" tires. I woul dbuy them again.
2kSoulara
Postby Dawgz » Tue May 29, 2007 7:18 am
235/45/17 ?
remember, with every tire change, its reccomended that u flush and fill ur Blinker Fluid.
Postby SpikedMantis » Tue May 29, 2007 11:14 am
woa_its_j3ff wrote:and my MAIN concern this time when getting tires is to eliminate the tire/fender gap as much as possible. my current tires are way too "thin" and already make the gap bigger than it already should be without my drop.
The best way to do that is to increase the sidewall, perhaps 50. However, then the width will need to decrease. I'm running 215/50/17, but I'm running spacers in the rear with rolled fenders. It also depends on the offset. However, this size makes almost 1 finger or less between the tire and fender.
This is the space where I should write something witty or clever, hoping to show some personality.
SpikedMantis
Postby woa_its_j3ff » Tue May 29, 2007 3:33 pm
2kSoulara wrote:I have 225/45/17s and i just got some Khumo Ecstas for 385 total from discounttire.com. These tires are mad quiet! grip great and look great they are excellent "budget" tires. I woul dbuy them again.
mm I think I'll go with that setup. any pics man?
SpikedMantis wrote:The best way to do that is to increase the sidewall, perhaps 50. However, then the width will need to decrease. I'm running 215/50/17, but I'm running spacers in the rear with rolled fenders. It also depends on the offset. However, this size makes almost 1 finger or less between the tire and fender.
any close up pics?
Dawgz wrote:remember, with every tire change, its reccomended that u flush and fill ur Blinker Fluid.
blinker fluid was serviced every 2000 miles :lol:
Postby SpikedMantis » Tue May 29, 2007 4:50 pm
woa_its_j3ff wrote:
any close up pics?
Best I can do for now:
SpikedMantis
Users browsing this forum: Google [Bot] and 51 guests
