SolaraGuy.com • View topic - white reverse gauge installation
Postby Dawgz » Tue Jun 05, 2007 4:03 pm
I saw these on the forum (pics) and looked on ebay, they are pretty cheap to buy.
Are they easy to install? what problems have you guys run into when installing these? whats the procedure?
http://cgi.ebay.com/ebaymotors/97-98-99 ... otohosting
any problems after they are installed?
thanx in advance.
Postby tito53 » Tue Jun 05, 2007 4:09 pm
theyve gone waaay down. i think ive seen them cheaper than that a few days ago on ebay. ive heard a lot of ppl messing up their gauges when they install it
tito53
Postby woa_its_j3ff » Tue Jun 05, 2007 4:09 pm
you'll have to turn em on with a switch, or maybe wire it so that it turns on when your parking/headlights are on.. I think it's a simple 2 or 3 wire hookup.
there is a tutorial in here somewhere but wont bother searching since the search function is still messed up.
they just slip over your existing gauges. but be careful. DONT MESS with the needles otherwise your SOL.
good luck..
Postby Dawgz » Tue Jun 05, 2007 4:37 pm
iite then fck it, i dont really care for them.
Postby AznDragonV » Tue Jun 05, 2007 10:32 pm
well i bookmarked the thread a long time ago when i did mine.. it was easy..jus be very careful..and if you get them from Procarparts.com as suggested in the tutorial, you dont have to turn them on each time ..there is a switch, but u can switch it on and it always comes on..where as the ebay ones have ths button thing that you need to press each time
well here is the link if you are goin to do this
http://www.solaraguy.org/viewtopic.php? ... ior+lights
AznDragonV
Postby SolAraB » Tue Jun 05, 2007 11:44 pm
hey i actually installed these a couple weeks ago......it possibly the easiest thing i have ever done.......as far as wiring just take your ground and of course wire it to any screw that will work and for the power wire i just hooked it up to my taillight fuse so it lights up when i turn on my headlights just like my old gauges did.......need more help just pm aight?
SolAraB
Postby SleeperSolara » Wed Jun 06, 2007 9:01 am
The reverse glow gauges are not that not to install they are over-lay gauges.
I got mine from Ebay, i re-wired them to only light up blue, cause it came wit the option of blue or green, and i only liked blue on the gauges so that is how i wired them up.
For the dimmer i cut the dimmer out, and plugged the dimmer wire into one of the plugs behind the gauge cluster, i think i blew out like 2 fuses figurein' out which wire to plug it wit.
Postby SolAraB » Fri Jun 08, 2007 9:24 am
Mine came with a dimmer too but instead of cutting it i just left it on full blast and hid the dimmer behind the fuses..........
SolAraB
Users browsing this forum: Google [Bot] and 51 guests
