SolaraGuy.com • View topic - DIY: Fender Rolling, it worked (kinda)
Postby hari-bhari » Thu Jun 07, 2007 2:41 pm
So i set out to roll my fenders today cuz the shop wanted 160 bucks.
Here is what the fender looked like before
First, I taped up an aluminum baseball bat so it wouldnt scratch up the car (it was ultimately pretty pointless).
I then proceeded to heat up the area with a hair dryer (also of questionable effectiveness)
Over the course of 20 minutes, i rolled the bat back and forth, up and down, using the tire of leverage.
End result
I did succeed in getting about 3-4mm of the fender rolled upwards, which may be enough. In the process tho, I cracked the paint in that area (nothing is visible).
How should I seal this up so it doesnt crack further?
hari-bhari
Postby krawzyazn » Thu Jun 07, 2007 3:10 pm
thats just retarded just pay the $40-60 and have it done NICE not GHETTO!
and man if they charging 160 the rippin people off
Postby Biggi_e » Thu Jun 07, 2007 3:12 pm
i know many people that do it like that and never had problems. most places in my area charge 100-200 for the fenders to be rolled also.
Postby indiglosolara » Thu Jun 07, 2007 3:40 pm
If you were in So. Cal I do fender rolling for allot cheaper... and I use a REAL fender rolling tool...
indiglosolara
Solara 2 xB
Solara 2 xB
Postby ThatVietGuy » Thu Jun 07, 2007 5:30 pm
I think you just needed a REAL heat gun :-?
ThatVietGuy
Postby hari-bhari » Thu Jun 07, 2007 7:28 pm
krawzyazn wrote:thats just retarded just pay the $40-60 and have it done NICE not GHETTO!
i have no problem paying 50-60-70 bucks, but i cant find anywhere that will do it other than this place that charger 160!
hari-bhari
Postby Jon11582 » Thu Jun 07, 2007 7:49 pm
Even in the "ghetto way", Your supposed to use a wooden baseball bat, but you gotta use what you got right?
Throw some touchup or rust sealant on that cracked paint. That can rust later on.
2000 Black Solara SE
Jon11582
Postby ---CAMRAZY--- » Thu Jun 07, 2007 8:13 pm
100 bucks in SoCal gets you a roll and pull...
40 bucks gets it shaved.
60 gets it rolled...
But its not that bad, I have seen worse.
Postby hari-bhari » Thu Jun 07, 2007 8:17 pm
Jon11582 wrote:Even in the "ghetto way", Your supposed to use a wooden baseball bat, but you gotta use what you got right?
thanks for the tip. i was thinking either the touchup or clear nail polish. it didnt crack cuz of the bat, it jus cracked cuz its bent so sharply
hari-bhari
