SolaraGuy.com • View topic - Cheap Horsepower?
Cheap Horsepower?
Cheap Horsepower?
Postby NASTY » Fri Apr 18, 2003 9:39 am
I found this on some corolla site, it kind of makes sense...what do YOU think?
"One cheap way to get extra power and fuel economy is to wrap your exhaust manifold/header with heat resistant exhaust wrap/tape.
"When exhaust gases are pushed out of your cylinders to your exhaust manifold, the air surrounding the manifold begin to cool the gases. This cooling process reduces the velocity of the escaping gases and the engine must 'work' to push the gases through your exhaust system.
"Wrapping the exhaust headers with exhaust wrap maintains hotter exhaust gases that exit the system faster through decreased density. Increased exhaust scavenging is produced, along with lower underhood and intake temperatures. I would also venture to guess that my catalytic converter operates more efficiently since hotter gases would elevate burning of pollutants.
"I purchased the exhaust wrap by a company called Thermo Tec from a JC Whitney catalog for around $30. I installed the wrap on the header and a portion of the exhaust pipe leading from the catalytic converter to the muffler.
"This mild enhancement resulted in a 5 - 7 HP gain ... the power surge starts at around 3,000 rpm. I haven't had the chance to monitor the fuel economy gains."
'01 SLE V6
NASTY
Postby Flipside909 » Fri Apr 18, 2003 9:44 am
It helps, but you won't notice seat in the pants performance like the post claims.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby TadS » Fri Apr 18, 2003 3:39 pm
Yeah, I did this. Basically, I did it to try to cool down the air my intake was getting. I am not saying whether it actually adds horsepower, but I will say that my under hood area is much, much cooler, and I am sure that is a good thing. For 30 - 50 dollars I would say it is a win - win proposition.
TadS
Postby Mole » Sun Apr 20, 2003 12:36 pm
cheap HP can be braught by nitrous... not reccomended if you go higher than a 50shot, but it is cheap.
