SolaraGuy.com • View topic - Auto dimming mirror modification
Postby KeepItSimpleStupid » Fri Jun 15, 2007 10:01 pm
When I purchased the vehicle in 2000, I found that the dimmed intensity didn't suit me. My memory suggests that it was probably too dark.
I held a pair of sunglasses over the sensor while driving and was extremely satisfied with the result, so I glued a small piece permanently in place. I think I used contact cement.
Worked like a charm.
KeepItSimpleStupid
Postby SolaraGuy22 » Fri Jun 15, 2007 11:24 pm
Okay, you're going to have to make an intro post and tell us WTF is going on.
SolaraGuy22
SolaraGuy Pimp
SolaraGuy Pimp
Postby Yanks0114 » Mon Jun 18, 2007 8:32 am
SolaraGuy22 wrote:Okay, you're going to have to make an intro post and tell us WTF is going on.
His auto dimming mirror was getting to dark for his liking so he put a sunglasses over the sensor and now it doesn't get as dark.
Postby theprodigy79 » Mon Jun 18, 2007 8:57 am
I had the auto-dimming rear view in my '04 and it was fine... Of course I had tinted windows, so that reduced the intensity of the light reaching the sensor on the mirror and may have caused it not to dim quite as much...
Anyways I never had any issue with it (even before I tinted if I remember properly).
Interesting trick none the less, I'd just be careful not to block out too much light, as it may not serve its purpose otherwise...
Welcome the the boards btw...
-James
theprodigy79
Postby Sebas007 » Mon Jun 18, 2007 9:48 am
James...your avatar is so funny ! :P
Postby KeepItSimpleStupid » Mon Jun 18, 2007 10:42 am
Well, at least a few people knew WTF was going on. Cheers to them.
I actually compared the dimming to a 2000 Impala and I liked the way the 2000 Impalla changed the intensity. So, after a little experimenting I came up with the polorized sunglass trick.
I tried to take a picture, but the modification blends in all too well.
KeepItSimpleStupid
Postby ---CAMRAZY--- » Mon Jun 18, 2007 11:10 am
So why not just buy a non-dimming mirror?
Postby yevhend52 » Mon Jun 18, 2007 11:44 am
or you can just push the off button on the mirrorand it will stop the auto diming
2000 SLE V6
yevhend52
Postby kingkakyle » Mon Jun 18, 2007 11:46 am
but i bet it still dims a bit, which is wat he wants
