SolaraGuy.com • View topic - stiffer motor mount options?
Postby TMMK Toy » Sat Jun 16, 2007 5:33 pm
Anyone here making stiffer motor mounts for the 4th gen camry or inserts? I've found two inserts so far and also wondering if anyone makes an upgrade for the mount located right by the pass. side strut tower? The one that's is prob. the most accessible. Not sure if it's technically a mount or not but I know companies like Weapon R make replacements for other vehicles. Oh and this is for a 1mz
TMMK Toy
Postby SleeperSolara » Sun Jun 17, 2007 12:50 pm
Yeah for the passenger strut mount, the techincal name is a Dogbone bushin'.
Cause it looks like a dogbone bushin'.
That is the only offerin' is from SuperPro.
Ther right rear engine mount and front right engine mount is not offered anymore cause not that much interestin the right rear engine mount....
Postby Eye8Pussies » Sun Jun 17, 2007 1:43 pm
just use 3m window-weld and make your own
becareful to not smooth out the inside of the dogbone mount too much though, or else the polyurethane won't stick well and eventually pop out (especially when it gets really cold)- this is from personal experience
Postby SleeperSolara » Mon Jun 18, 2007 6:36 am
Eye8Pussies wrote:just use 3m window-weld and make your own
That will work also, but won't last as long.
I saw "Turbo" or "Sport Compact Car" do that to some motor mounts.
